J D - Model 60
S Turley
02-21-2007 07:23:17
Are parts interchangeable on a John Deere Model 60 from 1953 thru 1956? I would appreciate
you input.
zwr
02-21-2007 16:12:17
 Re: J D - Model 60 in reply to S Turley, 02-21-2007 07:23:17
I think JD made the 60 in a Standard model on up to the time the 60 was discontinued altogether. Its main case was different from that of the more popular Row Crop. I think some drivetrain parts were different too, things like gear ratios.
Glen in TX
02-21-2007 07:53:48
Some differences like FIT mentions and like single or dual induction carb, manifold and cylinder head are ones I can think of but those will usually interchange. Parts Catalog PC244 covers all JD 60 two cylinder tractors. Call Ed at 812-537-4622 or JD publications 800-522-7448 for manuals.
BLinWMi
02-21-2007 16:25:45
 Re: J D - Model 60 in reply to Glen in TX, 02-21-2007 07:53:48
Just wondered, did the 60 ever come with a single induction carb? I had a neighbor years ago that had a 50 with single barrel carb but from my understanding, the 50 was the only one and that was just to use up old stock B parts. I have never seen a single barrel carb on a 60, my 60 is one of the very first, with a one piece pedestal, and it is 2 barrel. just curious
F-I-T
02-21-2007 20:03:59
 Re: J D - Model 60 in reply to BLinWMi, 02-21-2007 16:25:45
The single barrel carb ala the "B" and the "A" was used on the models of the 50/60 that were all-fuel/distillate engines. Later on the all-fuels got duplex carburetion, the 60 after S/N 6013899, and the 50 after 5015950.
John Van Valkenburgh
02-21-2007 19:34:02
I know you could get a model 50 with a single induction carb, but I'd be surprised if the factory would sell one except on a special order basis. The dual induction carb was one of the major selling points for the 50, 60, 70 series.
I don't know if the same is true for the 60 but the 50 had 3 different cooling systems which evolved over the production. My '53 has the older radiator shutter system with no thermostat. Takes forever to get the coolant up to temp. Later models had a thermostat and a water pump with a bypass hose.
Don't know if Power Steering was available for the '53 production year although I suspect it was. Most '53 model 50's I've seen are manual steering, live PTO and Roll-o-Matic. The later 50's (1954-1956) are often seen with Power Steering.
I was surprised to find that there are apparently quite a few 50's that were ordered with the older (non live) PTO. Perhaps they were worried that the "live" system with a separate clutch might not be as durable. Never had a problem with my live PTO though.
John
1953 Model 50
F-I-T
02-21-2007 07:43:11
There are some in-series breaks where housings, pipes, and such, are different, as well as options like live PTO, Rockshaft, and Power Steering that make for certain parts differences between any two tractors. It depends on the specific parts that you are speaking of, but for a great percentage of the parts, they were common across all years, but you cannot with say with certainty that you could build a '53 model from a '56 and vice versa. A parts book will show you the differences real fast.
Frank
F-I-T
02-21-2007 07:43:05
Frank
