injector boots
Kanuck
02-20-2007 19:51:59
Hello, sprung a leak on one of the rubber boots above the injectors on my 3020D. Since im in there i want to change all 4. Is it nesessary to bleed the system afterwards or any other concerns? Thanks for your help.
zwr
02-21-2007 17:04:45
 Re: injector boots in reply to Kanuck, 02-20-2007 19:51:59
Years ago I bought a pair of pliers that was especially notched for clamps like the ones you're lookin' at. Makes the job much easier.
Kanuck
02-21-2007 17:20:25
 Re: injector boots in reply to zwr, 02-21-2007 17:04:45
Yup could of used your pliers. All went well but i fought with the clips a little. Anybody within earshot may have heard some words they might not want to hear twice in a lifetime though...lol Thanks to all for your help and have a good one eh?
Jason Z in MO
02-20-2007 21:00:22
I've done a few on 4020's should be the same deal. Be careful of the steel fuel return rail. It can get bent easily. I would remove / loosen all the spring clamps and work your way back and forth loosening all at once. They seem to get stuck... I broke a couple of spring clamps too. So if you pick up parts before you do the work, you might want to grab a few. They were all available at Deere.
Maybe I just squeezed them too much but they seemed to break easy.
otto stook
02-20-2007 20:01:40
No need to bleed,,straight forward deal,,
