'49 john deere a
cprhead
02-20-2007 19:33:06
this tractor has what appears to be fins that would close to cover the front of the radiator, does anybody have any idea where i would go to find replacements? thanks
cprhead
P Browning
02-21-2007 06:14:15
 Re: '49 john deere a in reply to cprhead, 02-20-2007 19:33:06
See Green Magazine, Feb - page 62 for an ad by Tim Sieren (319) 648-4042 if you are looking for one in the after-market. New they can run up to around $250. Otherwise, in addition to Marlin Smith, try Tom Shepard (715) 265-4988 or Detwiler's (715) 659-4252.
Lots of sources -- just a bit on the expensive side, and if they are going to charge you anything over a $100, make sure it is loose and not missing any parts. You are looking for a radiator shutter assembly.
The way you have described your need indicates you do not have a Parts Catalog for your tractor. It is very hard to do much for one of those old tractors without one + the operator's manual. Call Deere Publications (800) 522-7448 with tractor model designator, serial number and your credit card in hand and you will receive the right stuff. Beware of SM-2000 -- it is a specialty service manual dealing with tooling, engine valves, carburetors and electrical systems ONLY -- not a manual for the whole tractor. Deere did not publish a service manual for your tractor, and so you will be seeking a shop service manual printed by Primedia and it is sometimes referred to as the I&T book. At any rate, Primedia prints many such books and the one you seek is desginated JD-4 widely available on eBay and from many after-marketeers. (PatB)
johns48jdb
02-21-2007 04:50:26
try marlyn smith in ia for used parts at 712-489-2570. nice guy to deal with.
Dave in SV
02-21-2007 04:08:47
I bought a real nice, clean set on eBay about a year ago. The control rods were hard to find, so I bought rod stock and made my own.
AA2240R is the part number for the complete shutter assembly.
F-I-T
02-20-2007 19:49:00
Those are manually operated radiator shutters used to regulate the temperature of the engine, since it is thermo-syphon, no water pump from the factory, and no thermostat.
I think someone is reproducing them, but they are very expensive. Most folks are able to find a suitable set on eBay or from any of the host of parts vendors. Are yours shot, or can they be saved if the rust and grime are removed? I cleaned the set for my "H" using electrolysis and they came out fully usable in a couple of days.
Frank
cprhead
02-20-2007 19:53:22
 Re: '49 john deere a in reply to F-I-T, 02-20-2007 19:49:00
no question about it they are shot.
thanks for the help.
cprhead
