JD 420 Hard to Start
Mervin Emerson
02-20-2007 11:11:23
I have an old JD 420, I believe they were built in the late 50's. It has always been hard to start. I only use it on weekends to bushhog, so it gets may 50 hours a year. When I first try to start it, it will barely turn over or not at all. I keep bumping the starter and finally it will turn over with enough speed to start. Once it has operated for a time, it is even harder to start and sometimes must set for a while before starting. I haf it overhauled perhaps 10 years ago. I appreciate any advice. Thanks Jay.
buickanddeere
02-21-2007 12:49:51
 Re: JD 420 Hard to Start in reply to Mervin Emerson, 02-20-2007 11:11:23
If in tune they start easy. I was checking the fit of a hand start crank in the snout of the 40 during one cold Christmas day. I was squatted down giving the crank a slow careful test turn to avoid scratching the paint. Suddenly there was a putt and a snort then the d*m thing was running. Gave me a right good suprise and I leaped away figuring it maybe even in gear and wanted to run me down. Unknown to me my father thought I was trying to start it and had the ignition on and the choke pulled.
Hayfarmer
02-21-2007 07:37:09
I have a JD 430, basicly a 420 with facelift. My uncle bought it new and it seemed like it always rolled over slowly. After I inherited the tractor I converted it to 12 volts with an alternator. I ran it every day in the winter to feed cows. I wanted to run lights and 12 volt lights are much easier to find. It rolls over quickly and starts almost immediately. I also converted it to electronic ignition as I had a problem keeping points adjusted. You don't mention your battery or how old, maybe it isn't good. As others mentioned battery cables, ground and hot are important, get the largest you can find with good connectors on battery, the replacement ones that clamp to the cable loose a lot of power. Keep the cables as short as possible. Timeing can be an issue, I tiem mine with a timeing light but you can do it by the book also or by ear if you know what to listen for. Check points as if they are worn that will throw timeing off. If it runs good after it starts they are probably ok. Make sure cables and battery are good, if still rolls over slowly check starter as mentioned below.
J Emerson
02-21-2007 10:19:47
 Re: JD 420 Hard to Start in reply to Hayfarmer, 02-21-2007 07:37:09
Thanks to everyone for the help.
Jay
J Emerson
02-21-2007 04:51:34
It's still the original 6 volt system. Thanks for all of the help. Jay
J Emerson
02-22-2007 06:04:01
 Re: JD 420 Hard to Start in reply to J Emerson, 02-21-2007 04:51:34
I should have been more clear, it does actually start easy, it just turns over slow. Somtimes when you hit the starter it wont trun over at all. You keep hitting the starter and finally it will turn over once or twice, real slow. Finally it turns fast enough and it starts right up. I'll take a look at the cabels and connections this weekend. Probably change out the battery. Maybe take off the starter and get it rebuilt. Thanks again.
lgc
02-20-2007 19:11:09
My 40 jd, similar tractor has always started easily. But it does like to be choked. Make sure choke is working and being used. But it does sound like you have some problem with battery, starter, connection as others have mentioned.
Ed the wine farmer
02-20-2007 13:33:40
If the battery is good and all of the electrical conections are clean and tight, the next step is to check the starter. Remove the starter and the wire conected to it. The nut with the Allen screw in the center should make a good ground, if not, clean it. Now check the brushes-if they are short-replace them. Now look at the springs that push the brushes onto the com (copper bars). Are the copper bars flat(good) or unevean (bad). If they are bad, they must be cut down on a lathe and the mica spacers between the copper bars will need to be recut.The only other problems could be bad windings or bad barings. There are people that fix these things (moter shopes). Just go to thr bank and pick up a pound of money. Good Luck
Meervin Emerson
02-20-2007 14:33:56
 Re: JD 420 Hard to Start in reply to Ed the wine farmer, 02-20-2007 13:33:40
Thanks for the help. What about the timing? Someone mentioned to me that might cause it to be hard to start. Thanks Jay.
Henry M
02-20-2007 11:26:22
Jay
First thing is to make sure you have extra good battery cables and like new connections. I went to extremes and put 00 on mine.
Wayne in Tn,
02-20-2007 16:24:01
 Re: JD 420 Hard to Start in reply to Henry M, 02-20-2007 11:26:22
You don"t say if the system is still the original 6 volts or converted to 12. If its 12v it should turn over extra fast. If still the 6v, then maybe the battery is bad. But as Henry mentioned, those battery cables must be large and with clean connections at both ends. Those little cables like a 12v system uses, do not work well with a 6v system.
Remove the ground cable from the dash and sand and clean it, making sure of a good ground.
