Difference between MFWD and 4x4?
CharlieMc
02-20-2007 05:44:29
What is the difference between MFWD and 4x4 in describing 4 wheel drive tractors? I'm been looking for one and have seen models listed both ways. If there is a difference which is better? I was looking for a late 70's or 1980's model at about 50hp (John Deere of course). Is there a good recommendation or some model to stay away from?
Thanks.
Geoff Mathews
02-21-2007 00:12:40
 Re: Difference between MFWD and 4x4? in reply to CharlieMc, 02-20-2007 05:44:29
If you are working on steep ground hydraulic drive will not give the same braking when descending - my 730D is MFWD for that reason.
JLG
02-21-2007 15:21:33
 Re: Difference between MFWD and 4x4? in reply to Geoff Mathews, 02-21-2007 00:12:40
I almost post a message the other day to see if the guy with the 4wd 730 got it working yet. I couldn't remember your name but last I heard you were missing a few linkages weren't you? Is it all together now? I remember from the pictures you posted before that it was a neat looking machine!
Mike M
02-21-2007 13:02:28
You got a 730D with MFWD ? send us a picture of that !
G/MAN
02-20-2007 15:58:34
The term "4wd" generally refers to large articulated or rigid-frame tractors with equal-size tires all the way around that usually do not have a means of disconnecting power from the front axle - both ends are driven at once. "MFWD" (mechanical front wheel drive) or "front wheel assist" tractors generally have smaller tires on the front and the front axle can be mechanically disconnected from the rest of the powertrain in some manner or another.
nickg
02-20-2007 07:36:37
here in southern indiana if you say 4wd tractor your talking about a big articulating tractor and mfwd is a tractor with a hydraulic controlled front end. I have seen sum tractor companies put 4x4 on their utility tractors but they are really just mfwd.4x4 and mfwd are one in the same.
nickg
02-20-2007 10:18:57
 Re: Difference between MFWD and 4x4? in reply to nickg, 02-20-2007 07:36:37
my oops. didn't mean hydraulic powered.Been couped up so long I think I am loosing it.
Ken52M
02-20-2007 09:54:58
Are there different terms for:
Straight tractor w/ shaft driven front?
Straight tractor w/ hydralic assist front?
KB
Glen in TX
02-20-2007 17:07:36
 Re: Difference between MFWD and 4x4? in reply to Ken52M, 02-20-2007 09:54:58
MFWD = mechanical front wheel drive.
HFWD = hydraulic front wheel drive. 4WD on a tractor usually means full time drive of all 4 wheels.
nickg
02-20-2007 10:16:59
now that you mention it. mfwd is just that. mechanical. and I bet that it could be in a smaller compact or utility tractor a 4x4 would be an all hydrostatic drive. If I had to choose I think mfwd would be better. I think you would get more poweer to the ground.
K.B.-826
02-20-2007 18:13:52
 Re: Difference between MFWD and 4x4? in reply to nickg, 02-20-2007 10:16:59
Many large tractors use hydraulic front wheel assist. Deere offered it as an option on most of the 20, 30, and 40 series tractors, they called it PFWD (P stands for "power"). Oliver had a few tractors that used it. Even to this day, combines and self-propelled forage harvesters can be had with hydraulic powered rear axles, as there is no easy way to run a mechanical driveshaft down to the rear axle. You are correct that a mechanical system is much more efficent, which is why MFWD has become the standard for modern tractors.
