Gas in my oil?
Dick Mattson
02-19-2007 15:07:27
I have gas in my oil, I change oil and filter and today when using the tractor I noticed the oil pressure was down and after shutting my 620 down and when I took the oil check stick out it just ran out the oil stick hole.
I hope someone can help me on this.
Dick Mattson
95CS
02-19-2007 16:57:45
 Re: Gas in my oil? in reply to Dick Mattson, 02-19-2007 15:07:27
More than likely, your automatic fuel shutoff needs to be rebuilt. There's a good article in the January-February 2007 issue of Two-Cylinder which shows how to overhaul these units.
johns48jdb
02-19-2007 15:22:46
probably your float is stuck and allowing raw gas to flood into the engine. remove the air intake line and see if gas runs out there. i'm not familiar with the later tractors, but if it was on a b there is away to replace the carb drain with a brass fitting and then attach a clear plastic hose to that fitting and holding it up beside the carb you can tell how high the gas is in the bowl. you may get by with just cleaning the carb but i would put a kit in it. take the float out and shake it. you may be able to feel fluid in it if its got a hole in it. you'll get some better answers than this here, but this is a starting place for you if your in a hurry to get it going. your going to have to change the oil and filter again right now. i'd be awful tempted to put several quarts of some cheap oil in it remove the plug wires where it want crank and spin it over and drain the oil again and then replace it with good oil. i wouldn't change the oil until your sure you have the problem fixed though. my 4 cents worth.
F-I-T
02-19-2007 18:01:49
 Re: Gas in my oil? in reply to johns48jdb, 02-19-2007 15:22:46
I don't think it's the float. If it was, it wouldn't start and run, or at not least well. He was running it today, so it's not flooding while running, right? My vote is for the oil-pressure activated fuel shut off mechanism. They still stock those diaphragms and sell them everyday, even after 50 years for a reason.
If the engine isn't flooding, then the fuel is probably running back down the oil pressure line, through the oil pump, and into the crankcase, so it cannot be detected on the plugs or in the cylinders. Pretty common.
Frank
