Carburetors
J Belcher
02-19-2007 15:02:36
What is the difference between a all fuel DLTX 73
and a gas DLTX 67 for a John Deere-B are they enterchangable?
Marvel Man
02-19-2007 16:02:34
 Re: Carburetors in reply to J Belcher, 02-19-2007 15:02:36
DLTX-73 is a all fuel single induction carb for JD B # B201000 and up and JD 50 5000001-5015950. DLTX-67 is gasoline carb for JD B # B201000 and up.
Kurt_JDB
02-19-2007 15:32:32
If you want to run "tractor fuel" you will need the DLTX-73. But you will also need the lower compression all fuel engine, not to mention the tractor fuel. I think it will run with gas OK. The two carbs have the same basic design, however the 73 has an economizer plug/orifice, and I beleive it uses a different nozzel. The DLTX-67 is the gas carb for the late model B.
I am wanting to restore my '51 B to allfuel status, and am looking for a All Fuel DLTX-73, if you have one and want to let it go.
Kurt
