39b mag squeal
kevinjg
02-19-2007 11:49:29
i just put a rebuilt mag from restoration supply on and it fires fine but makes an awfull noise i called them and got a machine any suggestions while i wait.
kevinjg
02-19-2007 13:46:17
 Re: 39b mag squeal in reply to kevinjg, 02-19-2007 11:49:29
i used a new gasket from deere,and it fit good i did not feel it was forced in place by the bolts it seemed to go on just fine.i took it off and spun the lugs then grabbed my old one and there is quite a difference the old one spins freely and the rebuilt one seems very tight,i have since talked to restoration supply and they have told me to return it to them.hope this works out it is kind of expensive.
Glen in TX
02-19-2007 13:06:30
Sometimes you need 1 or more gaskets to shim it out some so impulse works freely. If you hold mag on flange by hand it and it doesn't fit flush with 1 to 3 gaskets NEVER pull it down tight with bolts by force or you'll end up breaking and ruining the mag. If you already did that to new or rebuilt mag the squealing you hear may be the snap ring and broke aluminum part of housing that you broke by pushing the ball bearing out against inside of magnet on a Wico XH. If that happened you ruined the mag housing! Hope you didn't break it? Bushings and ball bearings not replaced on proper rebuild can cause squealing too. If the drive on your governor shaft isn't in right place or governor was took apart trying to shim while mag was on that can break a mag too. There has to be just a little slack between governor drive and mag drive cup and why I've always put 2-3 flange gaskets with a rebuild.
Maark
02-19-2007 12:01:25
Did you install a gasket {A5272R} between the mag and gov. case?
