HELP! 830 2 cly. fuel in oil problem
LWS
02-18-2007 19:42:27
I have a jd 830 es that is getting a lot, I mean a LOT! of fuel getting in the engine oil. I pulled the transfer pump off and discovered that somebody has replaced the seals, I rebuilt it completely and re-installed it. I removed the injection pump cover and run the tractor and I could not see any fuel dripping from anything. Should I remove the Valve Cover and check the nozzles and the lines next? It will add aprox. 1 qt of diesel to the engine oil in 1 hr. It runs excellent and does not smoke. Any help will be appreciated.
F-I-T
02-18-2007 19:59:11
 Re: HELP! 830 2 cly. fuel in oil problem in reply to LWS, 02-18-2007 19:42:27
Ab-so-lutely! A loose nut on an injector line will present those symptoms, as well as a cracked line, OR a leak off tubes that are supposed to be stuck in the manifold port on the valve side. If they are loose, or missing, or n ot engaged into the port, the excess diesel fuel goes into the crankcase.
