Slight Radiator Leak on my 1936 D
Kenc
02-18-2007 12:49:55
Just finished restoring my 36" D. Reassembled the complete radiator system. I have developed a slight leak, a drop every 10 seconds or so at the point where the bottom rad tank and side radiator and bottom strap meet. As you know there is a small space at this junction. I was very careful to use permatex aviation sealer and torque the bolts good and tight. Any suggestions are welcomed as to how I can stop the drip. I certaintly do not want to disassemble again. How about a recommended stop leak product additive. Your thoughts are welcomed.
Thank you.
KenC
02-20-2007 04:50:10
 Re: Slight Radiator Leak on my 1936 D in reply to Kenc, 02-18-2007 12:49:55
Thanks for all your suggestions. Will proceed accordingly. Best regards,
Kemper
02-19-2007 05:40:38
I would just get a bottle of Bars leak, dump it in and warm her up good, it will seal and stay sealed.
Glen in TX
02-18-2007 13:20:25
Had good luck with black pepper and those tablets from car dealerships. They just talked this over at tool talk....
Radiator stop leak:
>Link
>Link
Bob-Wyo
02-18-2007 19:55:05
 Re: Slight Radiator Leak on my 1936 D in reply to Glen in TX, 02-18-2007 13:20:25
I'm with Glen on the black pepper, been stopping leaks for years with it. Here's how I do it, as you know D's don't have a water pump so would take some good long hot running to get the pepper where you need it. Now drain first, add some pepper and try to get it toward the leak side add a gallon and then a little more pepper, etc. The better you can get it at the leak sourse the quicker it will seal, I would through in a can of that liquid Bars Leak also, mix it with your solution first. Just stopped a good leak in a A like this last week.
Hope we have been of some help to you, best of luck with Your D and enjoy it.
Bob
