720 pony and diesel motor
StuBC
02-18-2007 06:55:29
My next plan is to do some work on my pony motor. I have never had one off before. Manual spells it out pretty good. I was thinking about timing it when I dont need the 720 but we were wondering what could be done to let me tow start it with the pony off. I was thinking that water lines would be an issue to overcome. What do you guys think needs to be done. I take a long time to complete a shop project.
MyrlfromPA
02-18-2007 18:53:42
 Re: 720 pony and diesel motor in reply to StuBC, 02-18-2007 06:55:29
When I changed my 70d to electric start I had to make a braket for the throttle linkage and also put a breather on the oil fill hole.I think the factory breather is in the pony. Plus block the waterlines
StuBC
02-18-2007 07:31:48
Thanks Frank. Sounds good.
BTW - my 70 governor, distributor, timing project went well. Started and ran good 1/4 turn of flywheel. Thanks for the help. I got the gear from RABE on this site.
Mark Rabe
02-18-2007 11:28:15
 Re: 720 pony and diesel motor in reply to StuBC, 02-18-2007 07:31:48
Hi Stu,
Glad you got your 70 governor fixed. If you need anymore 70 gas or diesel parts, my email address has changed....
[email protected]
F-I-T
02-18-2007 08:04:27
Good deal! That work is pretty straight forward if you just take your time, measure precisely, then make the proper adjustments.
F-I-T
02-18-2007 07:10:31
You can block off the water passages, and remember to cover the oil drain hole in the top crankcase cover plate. Fabricate a small plate to cover the water jacket access on the rear right hand side of the block, and then create either a steel plug where the forward pipe enters the cooling manifold on the cylinder head, or an old piece of pipe with a waxed wooden plug jammed in. You just have to judge how long you need to make the plugs last.
Frank
