Everyone has you pretty much covered with some of the theory and adjustments, but I have a couple of comments that I hope might help. The clutch lever not staying forward means that the mechanism is not likely locking over center. This can be caused by some simple things from common adjustments, to worn facings that are letting the clutch pack appear too "thin". First, on any "new" two cylinder I have in my shop that has indicated clutch problems, I disassemble the parts accessible from outside of the pulley, not removing the pulley itself to access the dogs/toggles/bolts just yet (because most times this is not necessary unless the problem is very serious). You're just looking to first perform a cleanup of the outer side, knock out the dust, chase the threads if possible, inspect the two facings (one is located behind the clutch driver mounted on the crankshaft so that needs to be removed to access the inner facing). Clean the threads on the three "T" bolts as best you can, and brush out the dust in the vacated area (it's probably asbestos laden, so no sense in stirring it up TOO much). Now I install the inner facing, then the driver, tighten that down, torqueing it properly per the book, then the outer facing, followed by the cast adjusting disk, with the 3 springs underneath. Now install the three nuts. The book says to tighten them down evenly, and for me what works best is to spin them down finger tight on the newly chased threads ( I use an old nut with a vertical slot cut in it for a chaser), then I take them all down in three progressive torque wrench visits. The force setting doesn't matter, I'm just trying to get them slightly over tight and seated at the same force because I find it is easier to come off the force flat by flat than to tighten up to the end point that way. I also put the tranny in neutral, then intermittently rock the pulley left to right, maybe about 25*-30* in rotation to try and settle the operating sleeve and its pin into a point midway between the combined pin and slot wear range, sort of halfway between where it might lean to the left or lean to the right. By now (60+ years) most have a lot of play in the pin hole and the operating sleeve slot, but if it will settle into a central position, the clutch will tend to pull itself back to that point as it is the point of minimum resistance. I find it works pretty well for worn clutches. Now just lean forward on the clutch handle and back out each of the three nuts one castellation at a time until you get the proper feel of tension. If it does not snap, you might have to go to the pulley brake adjustment next as that can also affect the locking over center action as well. I personally do not recommend any machining on the operating sleeve until you have exhausted every other point of wear and play. I would say that normally, shaving the operating sleeve from its original length should be WAY down the list of possible problems. I've only had to do that once before, and it was a result of dog pivot holes that had been repaired out of location. I would suggest a repair that extreme only after you have removed all the play and wear from the toggles/dogs/t-Bolt shoulders/dog pivots/re-bush the operating fork/and re-face the bronze collar. Normally, seeing to these adjustments and repairs will restore the clutch to like-new feel and operation without resorting to a modification. BTW, I think the "G" that was mentioned refers to the cam operated operating sleeve style cltuch found in the "G" through S/N 13803, and those early units have a few special adjustments that are not the same as the dog/toggle/operating sleeve style used in every other Waterloo model. If this doesn't do the trick, you might have to remove the pulley to have a look see. If you do have to go inside, that's probably a matter for another thread, but oncwe there you'll want to clean and re-pack the bearing, inspect the dogs/toggles/T-Bolt shoulders, pins, pivot bores, operating sleeve pin play, and pin slot wear. HTH, [email protected] Frank
