2510 Ventilator Pump
Paul in WI
02-17-2007 19:37:59
My son and I are overhauling a 1967 2510 with a ventilator pump. Does anyone know the purpose of the ventilator pump? I know some of the early New Generations had this ventilator pump and then discontinued using it. What was the purpose? Why was it discontinued? My son and I have thought about leaving it out of the engine. Is there any issue with that? Right now I wonder if it has any benefit and is it just an un-necessary load on the engine? Thanks Paul.
Glen in TX
02-18-2007 10:02:12
 Re: 2510 Ventilator Pump in reply to Paul in WI, 02-17-2007 19:37:59
Must be earlier or early gas model? Diesel one we had didn't have a ventilator pump.
Paul in WI
02-18-2007 16:58:38
 Re: 2510 Ventilator Pump in reply to Glen in TX, 02-18-2007 10:02:12
It's a 1967 Diesel Powershift I purchased out of Canada. Paul
Paul in WI
02-18-2007 05:54:25
Thanks guys for your answers. I know it takes time to write these explainations. I appreciate the complete explaination. If we have any questions regarding eliminating it I might be back at you. My son feels a couple of pipe plugs will do the job. We need to look at what to do with the gear. I did a search this a.m. but none of the explainations were as complete.
Thanks again. Paul.
msb
02-17-2007 22:19:42
As an engine turns over the crankcase goes from miniscule pressure to miniscule vacuum depending on where the pistons are at at any given point.The crankcase ventilator pump overcame the vacuum with pressure air pulled from the air cleaner so the engine would never "inhale" dirty air and would always be under pressure of some sort.I thought it was a briliant engineering feat when if was first used.Unfortunately when the air cleaner became restricted, engines would pull oil from the oil bath air cleaner into the intake manifold.That wasn't a problem with tractors equipped with dry type air filters, but Deere decided the feature not worth the expense of installing them .Plus it eliminated the ever occuring packing seal and capscrew leaking problem with the pump which Deere didn't like to see on their tractors in the field.You will not hurt a thing in removing the pump.I have, over the years,disconnected or plugged a lot of them off.
Most other engines have adressed this vacuum problem with a wad of coarse filter media in or next to the breather tube or oil filler cap in older engines.
Gerald J.
02-17-2007 20:02:21
I guess it keeps the crankcase purged of fumes that might get combustible once in a while. It came to the new generation tractors from previous 2 cylinder tractors I think. And when the 3020 and 4020 went to the side console tractor the ventilator pump was deleted. I don't know how the rest of the crankcase ventilation was changed.
I don't think the ventilator pump has a great load on the engine though I've heard of it failing and causing a large and noisy load.
I have no information on the 2510/20 tractors at all.
Gerald J.
