JD 345 Failure to Start-Fuel Supply?
Dave Buffington
02-17-2007 14:30:05
Hi Folks!
After a winter of trouble-free operation, our 345 has suddenly decided that it will not start. It cranks well. There's spark at each plug. But fuel?
The filter only had a small amount of fuel in it. I disconnect the line to the carb, and a small amount of fuel drained back out. I removed the filter and cranked it: No fuel came out. I then took the fuel line and pushed it below tank level and fuel does drain out, but not quickly.
Any suggestions?
And...
Where IS the fuel pump on the 345?
And...
There is a bit of gunk in the bottom of the tank. How do you clean the pick-up hose?
Thanks!
Dave
