hydraulic cylinder for model A
Jon Hurley
02-17-2007 07:13:21
I just purchased a model 44 plow that has a John Deere cylinder on it already. There seems to be a small rod that runs parallel with the piston and a small round disc on the piston. What are these for?
Jon Hurley
02-17-2007 08:56:01
 Re: hydraulic cylinder for model A in reply to Jon Hurley, 02-17-2007 07:13:21
here"s a pic of the cylinder
Link
from your description, it probably is a numbered series cylinder.
thanks
F-I-T
02-17-2007 18:10:36
 Re: hydraulic cylinder for model A in reply to Jon Hurley, 02-17-2007 08:56:01
third party image
Yep, that's New Gen cylinder like we had on our 4020D.
95CS
02-18-2007 09:26:08
 Re: hydraulic cylinder for model A in reply to F-I-T, 02-17-2007 18:10:36
No, it's not. These type of cylinders were made in both high-pressure and low-pressure versions. The easiest way to identifiy them is where the hoses connect. The low-pressure version used NPT thread. The high-pressure version used an O-ring seal and SAE threads.
F-I-T
02-18-2007 10:02:26
 You are right! in reply to 95CS, 02-18-2007 09:26:08
third party image
You are so right! I didn't look closely enough at his photo. I always seem to forget that those "low pressure, hydraulic stop" cylinders were offered back in the days of the late styled or the numbered series. I know they show up in the late styled parts book, but I thought they were first offered from the factory on the 50/60/70 (the '50' book shows both cylinders, manual and hydraulic). I don't know when they actually became available. Maybe you know. I know our original '48 "A" had the two-post maunal stop type from the factory.
Frank
95CS
02-18-2007 10:25:02
 Re: You are right! in reply to F-I-T, 02-18-2007 10:02:26
This type of cylinder was first offered in April, 1953, or basically, when the Model "70" was introduced. Prior to that, JD cylinders were of the mechanical-stop type. I hated the hydraulic-override cylinders with a passion. Hit a little bit of a lick one time on a deal, and gathered every one of those we had, put them on a consignment sale, and bought new mechanical-stop cylinders for everything we had that needed one. Cost me a few bucks, but sure lessened the frustration load. Worth every penny.
Glen in TX
02-17-2007 09:57:57
A black cylinder like that is rated for higher pressure hydraulics of 2250 psi coming out with new generation JD tractors 3010, 4010, 4020 ect. on up. Green cylinders are lower pressure cylinders rated only at about 1200-1500 psi for 2 cylinder tractors and shouldn't be used with later higher pressure tractors. The black high pressure ones will work fine with earlier 2 cylinder tractors too just don't use the old cylinders with new ones as will blow out piston seals. The disc is a adjustable stop. You pull the lever out and unthread it some to loosen the disc so it can be adjusted along the length of cylinder rod. When disc hits the stop rod arm it should detent out the controls and stop cylinder travel if working correctly. The disc allows you 6 1/2" variable stroke of cylinder with the stop or you can move disc all the way out to clevis end for full 8" stroke. These cylinders are covered in operators manuals of all new generation tractors and parts catalogs also.
jdhbag
02-17-2007 07:53:30
If it is the cylinder that was made for the letter series tractors then it should have a rod with several holes in it on each side of the cylinder which pins went through to set the amount of cylinder rod travel for depth control. If it only has a single rod with an arm stickin out to engage the disc mounted on the shaft then its a cylinder that was made for the numbered series tractors. The disc is adjusted along the shaft for depth control. The disc triggered the arm on the small rod which in turn shut off the hydrauulic pressure to the cylinder. Hence stoping the cylinder shaft movement where you want it.
lejo
02-17-2007 07:25:53
There should be holes in these rods so a pin can be placed to set depth of of your plow. le
