Generator to alt
fumblefarmer
02-16-2007 19:20:47
Is it easy to wire in an alternator to replace the generator on my old 60jd.THANK YOU ANYONE
John T
02-16-2007 19:58:48
 Re: Generator to alt in reply to fumblefarmer, 02-16-2007 19:20:47
Heres how I wire a GM 10SI 3 Wire Alternator (to work like a 1 wire) and remember, it requires NEGATIVE GROUND !!!!! !
The big rear main alternator output terminal goes to the wire that used to be connected to the BAT terminal on the Voltage Regulator or Cutout Relay. HOWEVER if that wire wasnt already upgraded, when I convert from a Genny to an Alternator, I replace that wire with a 10 Gauge and it runs from the alternators main output up to the LOAD (NOT to battery/starter) side of the ammeter. I also replace/use 10 Gauge from the ammeters other SUPPLY terminal to the battery/starter.
The little side number 2F Voltage Sense Terminal gets connected (use a short 14 jumper wire) right up to to and with the big main output terminal mentioned above.
For the little 1R side Excitation Terminal, run a 16 or so gauge wire from the ignition switches IGN (which is HOT ONLY when ignition is turned on) terminal and in series with it place a 10 ohm 5 watt current limiting protection resistor (dont really need that much wattage power rating, but they are heavy duty built and easy to wire). Then in the rare event the tractor continues to run cuz of alternator backfeed when the ignition is switched OFF, I add in series a 5 amp 50 PIV minimum Diode. The diode must be wired with negative cathode end to the alternator and positive anode end to the switch. Again, the ratings are not that exact but about any diode over a few amps and 50 volts or so works.
Dont forget to change the battery to negative ground and the coil needs to be wired so the negative goes to ground via the distributor points and the positive gets power from the ignition switch and you have to reverse ammeter leads also if you�re just now changing polarities or it will read bass ackwards.
Good luck Ol John T in Indiana
Bob
02-16-2007 19:43:55
Here's the basics:
Third Party Image
fumblefarmer
02-16-2007 20:34:01
 Re: Generator to alt in reply to Bob , 02-16-2007 19:43:55
Thank you
