330 value
Cotton Picker
02-15-2007 17:53:47
Found one that runs good, needs some tin work. $7,000. Is it worth it?
test
02-25-2007 11:34:43
 Re: 330 value in reply to Cotton Picker , 02-15-2007 17:53:47
third party image
ddddd ddddd ddddd ddddd
5020s rock
02-16-2007 15:18:15
IF !!! that is a genuine--bona-fide 330
that is reasonable. i saw 1 sell for 24,000
and one sell for 19,000 at dennis polks labor day sale. i was speechless. the others guys have given
you sound advice on checking the integrity of that tractor.
Vermont John
02-16-2007 12:15:22
Sorry for this dumb question, but why is a 330 so much more valuable than the 40? Thanks.
pjbrown
02-16-2007 16:13:19
 Re: 330 value in reply to Vermont John, 02-16-2007 12:15:22
Due to the small number of 330 built. I'm from Vermont also...
Ten-Twenty
02-16-2007 16:30:57
 Re: 330 value in reply to pjbrown, 02-16-2007 16:13:19
There were 834 330 Standards built and 249 330U's. In my opinion, those are NOT numbers that should generate the $$$ that people are paying. There were only 1114 420U's built and they do not command the big $$$.
Mike M
02-16-2007 17:46:45
 Re: 330 value in reply to Ten-Twenty, 02-16-2007 16:30:57
I think it was all because so many wanted the whole set 320-820 or 330-830 ?
PJBROWN
02-16-2007 17:42:04
Ten-Twenty, Do you know how many 435 were made?? Do you know if they bring big $$ I think they had GM diesel in them ,but I'm not sure.
JD @ Antique Acres
02-16-2007 19:24:09
 Re: 330 value in reply to PJBROWN, 02-16-2007 17:42:04
A total of 4625 were built. Lately these models have been bringing a premium. $15,500 was the highest I have heard/seen one bring.
buickanddeere
02-16-2007 21:16:39
 Re: 330 value in reply to JD @ Antique Acres, 02-16-2007 19:24:09
A 435 should bring every bit as much or more than a 320 in similar condition. And if you want to use it they had optional live pto, five speeds etc that no 320 or 330 ever had. Power wise a 435 will walk all over a 320/330. The engine will start fine in cold weather if updated to modern 53 series specs.
Ten-Twenty
02-16-2007 13:13:39
Demand.
It is a tractor of choice for collectors. The production numbers are not all that dramatic, but for some reason it is a "must have" for collectors.
jCarroll
02-16-2007 05:21:50
The issue that buickanddeere didn't explicitly state is that shysters have "converted" a 40 with a stolen 330 serial plate from a $2000 tractor to a $12000 tractor. There are several differences, but to the casual observer they look alike.
So, be careful, unless your ante in the poker game is $7000.
buickanddeere
02-15-2007 18:04:49
Are you kidding? Grab a parts book and crawl over every square inch checking part numbers and signs of mixing & matching. Does the serial number plate look factory original? Can you find the engine block stamping number? Do you know the vender?
Cotton Picker
02-15-2007 18:43:03
 Re: 330 value in reply to buickanddeere, 02-15-2007 18:04:49
What do I look for on a 330 mixing and matching, where is the engine block stamping number and what will it say?
buickanddeere
02-16-2007 01:10:59
 Re: 330 value in reply to Cotton Picker, 02-15-2007 18:43:03
Engine oil fll location, dip stick location, transmission, final drives, casting date numbers of just about every casting. Which model of the 330 is it and what options? The engine block stamped in number is on the right side towards the rear. Mother Deere can run that number to verify it jives with the belhousing serial number. Is there any serial number type of ID tage anywhere around the top or sides of the transmission?
Cotton Picker
02-16-2007 04:41:38
 Re: 330 value in reply to buickanddeere, 02-16-2007 01:10:59
I just looked over it and did not give a close inspection. It is in the middle of nowhere down here so it is not going anywhere. I will see it again next week and look a lot closer. The seller is in no hurry.
Mike M
02-16-2007 06:14:16
 Re: 330 value in reply to Cotton Picker, 02-16-2007 04:41:38
Even in the middle of nowhere they may have an internet connection and be reading this and figured out by now they should of asked twice that for it. I'd get over there ASAP !
F-I-T
02-16-2007 09:41:56
 My $.02. in reply to Mike M, 02-16-2007 06:14:16
And this is where the game gets interesting. Here you have a buyer who would like to buy the tractor at as low a price as he can, and a seller who may or may not have a genuine article, and if he does not, might not even know he does not.
If the buyer is successful, and does purchase the tractor at a price so low that all his buddies congratulate him on making a "steal", then the seller finds out he had a "Picasso", he'll think twice about selling any of his other stuff to any those "tractor collecting bums with a new pick up and a trailer". So, all of us will have a problem the next time we try to go buy something because Miss Hazel will say that she'd rather see that "D" rust into a pile than to allow somebody to cheat her like they did the old Widow Higgins a while back.
Or the flip side. The buyer rushes to the deal in order to close it before the seller finds out what a "Peecassole" is really worth. So, the buyer does not perform his "due diligence", takes the hayseed's word for the pedigree of the machine, get it home and finds he has something truly less than a 330, and soon he's on this board crying about how he got shafted, when on the other hand, he was prefectly content to buy something for far less than it was worth.....
What's the problem with really talking to each other about what it is he has, and what concerns YOU have? Tell him a 40 year old tractor is only worth $7,000 or more if it is a model/subspecies. A good conversation might bring out tidbits like an original receipt, an agreement to hold it at your agreed to price while you engage a 330 expert in the interim (a small sum of earnest would probably go a long way here...), and maybe the old "Oh, and I have some implements in the barn for it, too". It will most likely leave you both feeling better about each other, and that you both got your money's worth, no more and no less.
I know nothing about, nor do I have any inclination to spend my money on such a tractor, so I'm not competition. Just ask yourself if you have $7,000 that you can afford to lose, because a good portion of it could fly away in the form of a chassis that is not a true 330, or expensive to replace parts and a proper paint job required to get it back into the spotlight condition.
Chuck730DSE
02-16-2007 11:14:37
 Re: My $.01. in reply to F-I-T, 02-16-2007 09:41:56
FIT, the same ones that whine about getting shafted, many times, not always, are also the ones that will lie to an old widow lady about the value of her "old tractor" just to make a big profit or to "steal" a nice collector model.
There are still some good folks out there, but you would be surprised at who some of the real shysters are, they are some of the same ones that talk all that crap about how honest they are.
I like your approach. If the seller learns that it is worth more, and raises the ante, the buyer still has a choice: pay more and closer to what it is really worth, or walk away.
What ever happened to being "fair and honest"? It seems to have gone out of style.
F-I-T
02-16-2007 12:28:17
 Re: My $.01. in reply to Chuck730DSE, 02-16-2007 11:14:37
Chuck:
My sentiments exactly!
Cotton Picker
02-16-2007 18:11:44
 Re: My $.01. in reply to F-I-T, 02-16-2007 12:28:17
I appreciate ALL your input, thanks. Will look at it again and take alot of pictures, I will try to figure out how to post them.
If I get shafted it's all on me! If not, I am smarter than my in-laws claim.
Time will tell, will keep you posted.
5020s rock
02-16-2007 20:33:37
 Re: My $.01. in reply to Cotton Picker, 02-16-2007 18:11:44
well, you did not say there were in-laws involved..... damn the torpedos !! do it just to show there finger pointin, scared butts !! thats my 2 cents!!!!! !!!!! !
