2940 brakes
Skybow
02-15-2007 08:40:16
I'm new to this tractor-only had it a month. When I try to depress either brake pedal by itself both pedals move in unison. The lever to locked them together is up and out of the way so this isn't the problem. It is very cold here in Iowa. Do I need to check the transmission filter and replace the fluid. Is there another connection somewhere else to check?
Thanks
WTW
02-15-2007 09:29:32
 Re: 2940 brakes in reply to Skybow, 02-15-2007 08:40:16
Is this a cab tractor or an open station tractor? If an open station tractor, I would look at brake valve where the pedals pivot on a common shaft. Sounds like both pedals are seized to shaft and shaft is turning in brake valve casting when it should not be. Pedals have a brass bushing in them and are supposed to pivot independently on this shaft. Shaft is retained in brake valve casting with a roll pin drove in one ear of casting. Pedals seized to shaft cause the shaft retaining roll pin to shear and allow the shaft and pedals to turn together as a unit. Take the brake valve, pedals and corner of platform from tractor as an assembly off and to a warm shop to disassemble pedals from shaft, clean. lubricate and reassemble. Floor plate and pedals will have to be reassemble independently on brake valve after brake valve is re-installed on tractor. Good Luck DW (Iowa)
skybow
02-15-2007 18:47:57
 Re: 2940 brakes in reply to WTW, 02-15-2007 09:29:32
THANKS A LOT
SKYBOW
