60 block price
Dairy Farmer
02-14-2007 18:08:11
My neighbor is geting his jd 60 back from the dealer after having a new manifold and radiator flushed heater put in ect. well they say the block is cracked or it has a bad head gasket. well we ain't gonna find out just yet because of lack of money. there was only anti-freeze in the left cylinder from what i could tell. would that be the gasket or the block? if it's the block, how much would a good used one be? Thanks, DF
buickanddeere
02-15-2007 06:51:52
 Re: 60 block price in reply to Dairy Farmer, 02-14-2007 18:08:11
The 60 as much or more than other tractors require a flat cylinder block and a flat cylinder head. And after 51+ years of service,tension, hot-cold thermal cycles. And previous torquing via Uncle Bubba who would know what a torque wrench was if hit with one. Torquing a stud hard into the block and bottoming it can split the casting. Bottoming can also leave too few threads for the nut to engage and torque properly. Odds are the studs and nuts have failed. New grade 5 or 8 studs/nuts should have hardened washers used under the nuts as well as the soft lead between the washer and head. Some swear by a wee smear of permatex around the gasket edges and it can't hurt. The thermostat should have a 1/16 hole drilled through it to allow a slow trickle of water and air bubbles to vent during warmup. Less thermal shock when the thermostat opens. Don't run without a thermostat or wear/exhaust fumes will increase and fuel efficiency/engine life will decrease.195F is good running temp. Don't load the engine heavy when cold. You can blow the gaskets on just about anything with a high hp load from a cold start.
Mike M
02-15-2007 03:32:42
Those blocks can have a crack around the stud holes and/or back a little bit about like where the ring ridge is they crack in a circle. Usually from nuts being overtightened. They also crack along bottom on the outside. These are the 2 main trouble spots on 60's
DSK
02-14-2007 18:38:01
Let's be optimistic and say it's the gasket, but there's no way of telling without pulling the head. Head gasket failure was somewhat common in the 60, more so than other models any way. You should be able to pick up a good block for around $300, but then your pistons might not match the bore in the block, so that would be another expense for pistons and/or boring. At any rate have the head surfaced while it is off, I have a 60 that had chronic head gasket problems until I did this.
