50 Block interchangeable with 520/530?
Obiwan
02-14-2007 18:04:50
I need to replace the block in a JD 50. Parts books seem to indicate it is a unique part. I'm pretty sure a late "B" won't fit, but will the block from a 520 work? Thanks.
DW
02-14-2007 22:17:26
 Re: 50 Block interchangeable with 520/530? in reply to Obiwan, 02-14-2007 18:04:50
I don't know what the problem with your block is.....but they can be bored and dry sleeved back to stock bore or whatever. I had that done to a "G" block at a machine shop in Sioux Falls South Dakota several years ago and have had no problems with it. Hope this helps you decide what to do with your "50".
obiwan
02-15-2007 18:27:08
 Re: 50 Block interchangeable with 520/530? in reply to DW, 02-14-2007 22:17:26
Thanks for the advice, all of you. Long story, but I started fixing this tractor for a friend, because it was burning anti-freeze. What was suspected to be simply a bad head gasket quickly turned into a bad head (numerous cracks). After boring the block to remove the ridge, we discovered that whoever bored it 45 over didn't properly align the holes, so we had to go 90 over to correct. Slap it together after decking and rebuilding the new head, boring, decking and honing the block and it started right up. Shortly thereafter the engine started to drag. After much head scratching and consultation, we tore it down again. Ruined the new pistons, apparently caused by antifreeze leaking again. Retested the head. No problems. Retested the block, this time with a pressure test. Porosity in the upper cylinders resulted in coolant leaking into the combustion chamber. Man, this project is wearing me down.
buickanddeere
02-14-2007 20:08:41
B & 50 have the spark plug in the cylinder block. The 520/530 has the spark plug in the head. I got lucky and found a 5-3 power block for a 50. Really put some snort in her. Sounds odd however, more like a cross with the "putt" of a 60 and the "bark" of a 50.
960
02-14-2007 18:28:05
The 520/530 are a different animal, NO.
