Marvel Schebler Carburetors
Anderson
02-14-2007 17:49:46
Is there a list out there some where that lists all Marvel Schebler Carburetors and what they fit???
Henry M
02-15-2007 18:40:51
 Re: Marvel Schebler Carburetors in reply to Anderson, 02-14-2007 17:49:46
I think he said all makes of tractors and did not specify JD. I have three old pieces of iron, JD, Ford, and Allis, and all have marvels. They are everywhere!!
Glen in TX
02-15-2007 21:58:43
 Re: Marvel Schebler Carburetors in reply to Henry M, 02-15-2007 18:40:51
The current Zenith / Marvel Schebler catalog is 1-800 that lists for about $45. The older catalog 1-400 weatherly index 602 covered Marvel Schebler and Zenith agricultural and industrial carburetors. You might be able to get a copy of 1-600 by contacting someone at Zenith but it is no longer in current price sheet. Any particular one you want to ID as I could probably tell you? 1-600 catalog doesn't have numerical order list telling you what they fit but does have applications by brand of equipment used on and covers most older equipment. Numerical order list only shows parts, kit numbers, & Zenith replacement numbers. You might also poke around old dealers or watch online ads and auctions for a old 1-400 catalog as some older MS carbs are not covered in other two catalogs. Zenith / Marvel Schebler
hwarrior23
02-15-2007 11:08:22
We have a John Deere carb. manual that we bought when a dealership went out of business that has the carbs all listed by number and what they fit.A "master list" of sorts. I now that it goes thru the two cylinders and into the new generations, but I am not sure how far.
Glen in TX
02-15-2007 12:25:28
 Re: Marvel Schebler Carburetors in reply to hwarrior23, 02-15-2007 11:08:22
JD SM2024 Carburetors service manual for JD tractors and engines. Does NOT cover any New Generation tractors but does cover carbs used 2 cylinders A to 830 for tractor engines and pony motors. Also covers carbs used in same era on power units, hay balers, beet harvesters, combines, cotton pickers, forage harvesters, and windrowers (swathers). Carbs used on new generation tractors are covered well in each tractor or units service or technical manual. JD Publications 800-522-7448.
P Browning
02-15-2007 16:52:26
 Re: Marvel Schebler Carburetors in reply to Glen in TX, 02-15-2007 12:25:28
Glenn -- This fellow sound like he is doing a research project and is looking for us to so his legwork for him. Check out his later post. (PatB)
Glen in TX
02-14-2007 21:44:07
Anderson
02-14-2007 18:34:10
Sorry...I meant like a master Marvel List for all makes of tractors.
P Browning
02-14-2007 18:27:31
That depends on what model range of tractors you are talking about.
For the lettered series (A, B, D, G, H and GP) go the the JD-H Restoration Site of www.jdhpubs.com and one-click on the Carb ID Chart.
For a bit of an expended listing, go to Robert's Carb Site of www.robertscarbrepair.com
And if you get lost, check in at the JD-H site (below)for a steer. (PatB)
