4020 hydraulic demon
gumba
02-14-2007 16:35:30
I have a 1969 JD 4020. Here's the problem. I can back up to a large round haybale and spear it. Then I can raise the three-point hitch up to any level---but when I pull the remote selective control valve lever to hydraulically raise the bale higher up the bale lifter, the three point immediately lowers to the ground. Where is the problem located and what do I need to do to fix it? Thanks.
msb
02-14-2007 19:45:56
 Re: 4020 hydraulic demon in reply to gumba, 02-14-2007 16:35:30
Try this: Raise the load on the 3 point hitch and shut the tractor off to see if the rockshaft piston o-ring is good.It should hold up the load or longer 10 minutes or longer.
msb
02-14-2007 19:49:54
 Re: 4020 hydraulic demon in reply to msb, 02-14-2007 19:45:56
Should have said be sure the L&D is set in D as Bob first said.If the rockshaft sensitivity is out if adjustment,I have seen that cause the problem you speak of.
Bob
02-14-2007 18:58:20
What are you operating with the SCV... a hydraulic top link? Or what?
Do you have the 3-point set in "DEPTH" contol mode?
gumba
02-15-2007 07:41:33
 Re: 4020 hydraulic demon in reply to Bob, 02-14-2007 18:58:20
The hay lift works like this. It hooks to the three point hitch of the tractor. The lift has a cylinder mounted on it that plugs into the SCV of the tractor. When you raise the TPH up then you can pull the SCV lever and it will raise the bale fork straight up allowing you to place the bale on top of a stack of bales or on a trailer. It is simply a combination of ways to lift a hay bale to a greater height. Thanks for the replies. Any info is welcome. I'll try the draft lever setting.
