I guess I'd think that if you just hooked them up in parallel, + to + to + to +, and - to -to -to -, the lowest charged (lowest voltage) "cell" in the string would take current to come up to the nominal system voltage of the adjoining cells, until all cells would be floating on the maximum system voltage, in fact the others would actually be "charging" the weakest cell. I think it's no different than using a small Ni-Cad charger for something like AA cells, which is wired for parallel cells. You can put in 1,2,3,or 4 cells, no matter, and since it is supplying 1.5 (or I guess 1.4V on a NiCad) across the output leads, any and all batteries come up to charge, if they are healthy and they take a charge. If you charge the cells this way, and one cell is found to be low on voltage or draw time, then that cell might be suspect of needing to be replaced. You could use a "Battery Tender"-type smart charge, and the system should float at the proper voltage and only when the cells fall below nominal, they'll take on some electrons. Now, an old dutchman's trick that I intend to try one of these days is to use a charger with say an output of 1 amp, feeding all the the cells hooked up in parallel, then wire a 6 volt headlamp in series and when the battery(ies) are fully charged, the lamp will glow brighter, burning off the current. I got this from an old electrician who said he used this method on his old stored cars. He fed into the cigarette lighter port. Said it worked great. FWIW, I could and have been wrong before. This offer void where prohibited by law.
