Balancing act
gold-leaf-deere
02-14-2007 12:56:41
I just had a 1937 D Engine balanced, The piston weight was interesting, the original 6 3/4 cast iron weighed 7299 grams, the new 7 inch aluminum weighed 7414 and 7425 grams. This is about 4 1/2 ounces difference between the cast iron and the aluminum.
Earl-IL
02-14-2007 20:26:06
 Re: Balancing act in reply to gold-leaf-deere, 02-14-2007 12:56:41
All the later 2 cyl run aluminum pistons. The quality of aluminum is much better than the early pistons.
Earl-IL
02-14-2007 20:25:58
gold leaf-deere
02-14-2007 19:17:44
Before I had the stock block bored, I talked to Don Dufner, He said that he had several sets of the 7 inch aluminum pistons running in the field and had no troubles. He had seen the current big pistons and concluded that they are stronger built that the ones that he had ran without problems. At least there are four "Piston Dealers" selling the aluminum pistons and they must be getting them all from the same shop. One of the dealers called me last week and said he was getting some more this week.
machinery-man
02-14-2007 13:01:00
Will the aluminum hold up in these engines. I've found that the top ring grooves seeem to get beat out with aluminum versus cast iron. A friend of mine has torn down dozens of them and says he never found a problem in the cast top ring grove.
Mike M
02-15-2007 03:44:29
 Re: Balancing act in reply to machinery-man, 02-14-2007 13:01:00
I have to agree. I have torn down many engine with cast pistons and I don't think I ever saw a broken ring. BUT I have had 1 G and 2 620's with alum. down and they all had the top rings busted and chewed all up. The 1 620 even had a piece of ring work up through to the top of the piston and started hammering against the head.The alum. uses thinner rings that must twist and break from wear. As all these engines were well worn past the rebore limits and in need of an overhaul. So you will have to work one long and hard to ever show up a problem.
Will P
02-14-2007 20:46:31
I have a set of .045 over cast iron all-fuel pistons out of a G that the top ring landing is beat out. Opened up my other G with WMW aluminum pistons, same thing, beat out. Now my A, and B with cast iron pistons is just fine.
Will P
G/MAN
02-14-2007 13:31:00
The aluminum may be softer and more prone to wear, but how many people rebuilding their Deere two-bangers with aluminum pistons are going to take them out and work them every day all day long as the tractors were often worked when new? My guess is that the averaged restored tractor is going to get fewer hours put on it in the next 50 years than it did in one year when new.
