JD420 front wheel shimmy
Henry
01-01-2000 12:11:08
Well used 420 standard has serious front wheel shimmy. Have adjusted steering box, replaced woodruff key in steering wheel shaft and tie rods seem fairly tight. Still have 40-50 degrees of free turn in steering wheel. What else should be checked/replaced/adjusted to get rid of shimmy??
Could king pins be part of the problem? Suggestions appreciated. Happy New Year
CLOONEY
01-01-2000 16:13:18
 Re: JD420 front wheel shimmy in reply to Henry, 01-01-2000 12:11:08
Henry, first thing is to have someone turn the steering wheel back and forth within the play while you look at tie rod ends,lower steering shaft (its hard to see), upper steering shaft (look for fore-aft movement), steering knuckles, axle pivot pin, etc. Then jack up ft. end of tractor by the center, grab left then right wheel & turn back & forth (within play) look for loosness at all above points. If all looks OK you probably have worn worm & sector gear.
