6600 7700 Series JD Hydraulic Question
Kevin Youngquis
02-13-2007 20:33:35
Sorry this isnt a tractor question. Does anyone know how many gallons per minute the hydraulic valves are rated at and one way or two way on this combine for the hydro, unloading auger and platform cylinders. please email if you know.
Bob
02-13-2007 21:14:14
 Re: 6600 7700 Series JD Hydraulic Question in reply to Kevin Youngquist, 02-13-2007 20:33:35
I have a factory shop manual for those combines at the shop, and I would GUESS those flow "spec's" are in there, somehwere, if a guy digs deep enough. I'll peruse it a bit tomorrow, and see if there are any easy answers.
There are orifaces, either in the actual valve or the fittings that restrict the flow of oil to the unloading auger fold cylinder, and the variable speed ground drive adjustment cylinder, I ASSUME the header lift gets the pump's full GPM's.
By the "hydro" section of the valve, I ASSUME you mean the section of the valve that supplies oil to the pulley adjustment cylinder on a NON-HYDROSTATIC machine, correct???
Kevin Youngquist
02-13-2007 21:22:13
 Re: 6600 7700 Series JD Hydraulic Question in reply to Bob, 02-13-2007 21:14:14
I meant to say variable speed instead of hydro on the original message. Thank you Bob for your lightning fast response.
Bob
02-13-2007 21:54:13
 Re: 6600 7700 Series JD Hydraulic Question in reply to Kevin Youngquist, 02-13-2007 21:22:13
I surfed over to JDPARTS, and it looks like there are even more variations by serial #, etc., than I thought.
It looks like auger fold was on it's own valve, and platform lift, reel lift, and variable traction speed made up the three-spool valve, in the setup I looked at.
I that what you are wondering about... the 3-spool valve? I WILL take a quick look tomorrow in the shop manual. The queation is, where is the flow restriction... IN the valve, in the fittings, or at the speed control cylinder. Do you have a machine serial #?
Kevin Youngquist
02-13-2007 22:28:56
 Re: 6600 7700 Series JD Hydraulic Question in reply to Bob, 02-13-2007 21:54:13
I dont have serial numbers in front of me. We have several donor machines to take parts off of and I hadnt decided which one yet. If the information isnt really obvious I will get the numbers. Thank you for your time.
