3010 pros? cons?
Brian in MO
02-13-2007 17:25:06
Hi guys, a friend of mine is looking at a 3010 gas and ask me for anything he should watch for? I'm really a IH man and have only used a few older deeres mainly 4020's so I thought I ask on here for any ideas of things to watch for. He won't use it a whole lot mainly to brush hog (6' 3pt), move bales, blade snow, etc. Also without knowing any specifics what would a good price range be figuring mechanically good, paint rough, tires 50%, 4000 hrs, gas, wide front.
Slybow
02-15-2007 08:30:00
 Re: 3010 pros? cons? in reply to Brian in MO, 02-13-2007 17:25:06
I have a 3010 gas that I've had for 8 years. Put around 100-200 hours per year on it. I has a Swartz wide front and an Allied 595 loader. I baled big bales, cleared the driveway, and brushhog with it. It was great tractor for me. This winter it lost rings or a piston as I have oil coming out the sparkplug hole. I'm going to have it rebuilt and sell it or sell it to someone who wants/can rebuild the motor. I'll keep the loader. I loved my old green 3010. Hate to see it go.
Brian in MO
02-14-2007 16:29:39
Thanks guys this gives me some things to help him look for. Thanks for your help, Brian
Gerald J.
02-13-2007 20:45:45
One of the big improvements for the '20 over the '10 was the PTO stub shaft. In the '10 it bolts on and the vibration of a brushhog can shake it loose when it causes lots of havoc. The '20 use a double ended spline shaft held in by a sturdy snap ring, different one for 1000 and for 540. If that's not been taken care on the '10 it can be a problem. The speed is shifted by a rod in the center of the shaft. If that rod is forced it breaks stuff and the tractor has to be split to fix the PTO.
Part of the gas consumption comes from there being no vacuum advance to give more advance for part throttle running. The IH gas hydrostats used more gasoline than the JD new generator gas tractors, but not a whole lot more and they didn't do as much work.
Gerald J.
Tom TN.
02-13-2007 20:11:12
well other than all the normal used tractor things some little things to look for with the tractor running at high idle and wormed up turn the stering wheel all the way left and thin all the way right if the front end turns slower one way it mite need rebuilt and if you have the chance to get it wormed up like you were working it losen the hyd. return line on the pump in front behind the screns the little line that bypass back to the tranny right side if it will fill a cup right away the seats in the pump are most likely woreout and if you do get it to working tempe and your remote valve is slower and the lift slows down whin hot temp is reached thin the supply pump in the bottom of the rerend is going out I have looked at tractors that had all of this alments and with a cotting of oil in the crank case breather tube from exces blowby you pay $3500 to $4000 for the tractor thin you spend $6000 on repairs over the next two years just playing around and painting it up that $8000 or so you could be making payment on a good tractor but Ide rather work on old green junk than make payment in closeing you are right to look at the gas tractors most have been worked less and on lighter jobes good luck
tsmith1499
02-13-2007 19:56:41
I have a 1961 3010 and have yet to see it burn as much gas as everyone would like to make you think they will. I plowed a 5 acre field and only used about 1/4 tank. I didn't think that was to bad. Considering the field had not been touched in over 10 years. I also bush hog about 10 acres with a 9' Woods pull behind and use less than that to mow all 10 acres. Do I have an unusual tractor, or does mine just run very good and is tuned up properly?
hilbile
02-13-2007 18:43:52
i have a 1961 3010 and is a BIG gas hog, we only use it for parades and odds and ends anymore but still is a hog. and it seems it lacks low end torque. to me it does, seems you gotta wind it up to 1500rpms before you git goin
Tyler Horner
02-13-2007 18:17:41
3010's that are gas in our area (Maryland, Delaware, Virginia) usually bring $3500.00 to $4500.00 in decent shape with some hours like you are describing.
Bob
02-13-2007 17:43:45
Make sure he realizes how much gas that thing will burn!
Brian in MO
02-13-2007 18:11:24
 Re: 3010 pros? cons? in reply to Bob, 02-13-2007 17:43:45
Yea I told him it would be hard on gas but he probably won't put 30-40 hrs a year on it.
woodbutcher
02-14-2007 04:28:33
 Re: 3010 pros? cons? in reply to Brian in MO, 02-13-2007 18:11:24
I have a 1961 3010 LP. It may have been comparable to the one you described when I bought it 12 years ago. The tires were 50% at that time, but they're still on it and still doing the job. I liked the fact that the paint was old and wearing off. It was an honest tractor with nothing hidden by a new paint job. It's a well-built machine.
Butch
