square nuts vs hex
Court
02-13-2007 12:36:00
why did JD use both as a type of fastener on their tractors and equipment?
Henry M
02-14-2007 09:17:06
 Re: square nuts vs hex in reply to Court, 02-13-2007 12:36:00
I also noticed square nuts in the local farm supply store that I frequent. Don't know anyting about the weight or quality though since I am not interested in that kind of detail.
CalJim
02-13-2007 21:59:25
Glen is right, the Deere hex bolts have thicker
heads. First tractor I restored I replaced them
all with new bolts. Currently restoring a 36 BN
and using mostly all original bolts. There is a
big difference when you really start looking at
them. The nuts too are what I would call "2x
heavy", try finding those without spending a
fortune. CalJim
The Dukester
02-13-2007 15:49:10
Cut square nuts and square head bolts are cheaper to make, especially if the hardware mfr. has the dies already. JD used them where the buyers would be using the stamped steel "knuckle skinner" wrenches they provided with the tractors and equipment...areas where access was easy and measured torqueing wasn't required. I think the styled letter models were about the last tractors to use them.
Glen in TX
02-13-2007 12:53:43
Square nuts were on horse drawn equipment and wagons so probably to just use up old stock in non critical areas like holding on sheet metal and fenders. Some places a sqare nut or bolt can fit against a iron or angle also holding it while the other end is tightened and just works better also.
woodbutcher
02-13-2007 16:19:11
 Re: square nuts vs hex in reply to Glen in TX, 02-13-2007 12:53:43
I had to remove a rear rim from my 3010 recently. The lug bolts were rusty, and a couple of them had stripped threads. These are 5/8" Class 5 bolts with square heads. I couldn't find any square head Class 5 so I used hex head bolts. One of the nuts was stripped, though, and I found out that the original lug nuts are a lot beefier than the hardened nut I replaced one with. By the way, the nuts are hex shaped.
Butch
F-I-T
02-14-2007 14:48:42
 Re: square nuts vs hex in reply to woodbutcher, 02-13-2007 16:19:11
third party image
I found this on JDParts.com. Did you mean the 5x8" "Special Square Bolt"? There are two listed depending on the model, row crop or standard. They are both listed as still available. Also, the nut at $.66 ea appears to be a standard 5/8" heavy hex.
Frank
Glen in TX
02-13-2007 18:46:38
Those were special bolts you had to get from JD with the square to fit snug in the rim lug. JD use to make most all of their own bolts and many had larger than todays standard hex size on nuts.
woodbutcher
02-14-2007 04:30:26
 Re: square nuts vs hex in reply to Glen in TX, 02-13-2007 18:46:38
I didn't think to look on the JD website. Can you still buy those bolts?
Butch
F-I-T
02-14-2007 14:12:22
 Re: square nuts vs hex in reply to woodbutcher, 02-14-2007 04:30:26
Last I bought came from Fastenal. They might have a store near you. They just opened a local store near me. I also got them from McMaster-Carr, www.mcmaster.com
F-I-T
02-14-2007 14:13:40
 Fastenal site screenshot in reply to F-I-T, 02-14-2007 14:12:22
third party image
Sorry, meant to attach a screenshot, too.
P Browning
02-14-2007 08:42:38
Woodbutcher -- I can supply nearly any size Machine Bolt (Square Head) in Grade 5. Drop me a note through the JD-H Restoration Site (below) for a quote. (PatB)
Glen in TX
02-14-2007 07:26:00
 JD Rim Lug Bolt in stock in reply to woodbutcher, 02-14-2007 04:30:26
Dealer here shows 28 of them in stock now. Many farm tire and wheel shops should keep them also. Part Number: 08H4694 Part Price: 2.51 USD On Hand: 28 Check Other Stores Description: BOLT, SQUARE HEAD Specification Weight 0.42 LBS 0.19 Kg Diameter 0.625 IN Thread UNC2A Length 4.000 IN Thread Length 1.500 IN Service Number Material or Grade A17F Finish B third party image
woodbutcher
02-15-2007 04:04:35
 Re: JD Rim Lug Bolt in stock in reply to Glen in TX, 02-14-2007 07:26:00
Thanks to all. That's good info.
Butch
