JD's speeds
bigboy12
02-13-2007 11:03:24
the JDs tend to have higher gear speeds or lower compared to farmall right?
Nylon
02-13-2007 15:20:55
 Re: JD's speeds in reply to bigboy12, 02-13-2007 11:03:24
I know that a farmall 460 with 15x38 in high gear is markedly faster than a 68 4020 synchro with 18.4x34 in top gear.
CLW
02-13-2007 12:21:48
If you are talking road gear and older tractors, the Farmall is faster.(comparing A to M or B to H for instance) Up to, but not counting road gear, the JD has 5 gears compaired to 4 on the Farmall so compairing say 3rd. to 3rd. would be comparing Apples to Oranges. The Early styled A and B were faster than the later single stick A and B and were only slighty slower than the M or H. The M and H ran about 17-18 MPH while the early styled A and B were abiut 15-16 MPH. The late styled A and B ran about 10-12 MPH.
donwisc
02-13-2007 12:19:46
Not sure what you mean by gear speed, if you mean ground speed or mph in each gear the 2 cyl JD were definitly slower in road gear but more closely matched in the working gears. Typically higher ground speed means less pulling power so it may be a mixed blessing.
Some one else may have some good comparative data on JD A B G verses IH H and M. I know a IH 400 could get a little scary running full throttle in high gear, eapecially if you had the usual front end wobble
