1955 jd 60 raod gear noise
jcv
02-13-2007 09:42:32
I have a 1955 jd 60 that makes noise in raod gear, all other gears are quite. Any info would be great, how hard to fix and cost would also be very helpful. Thanks for your time.
DSK
02-13-2007 14:06:12
 Re: 1955 jd 60 raod gear noise in reply to jcv, 02-13-2007 09:42:32
As long as the other 5 gears are quiet I wouldn't be too concerned. I have a 56 60 thats been on the place for 46 years and it's had the high gear whine for as long as I can remember. It's caused by normal wear in the first reduction gears and the noise is amplified by the pulley & pulley cover. To fix it would probably call for replacement of the first reduction gears,big $$$$. It's a common problem, when I hear a neighbors 2-cyl coming down the road on a quiet evening I can usually hear the gear noise before the putt-putt of the exhaust.
Mike M
02-13-2007 09:51:16
Can't really make a guess at how much $$ or how hard it is to you to fix/work on. To me not bad to tear into one. Thing is you can spend alot of time and money in one and even if you find alot of problems like bad bearings and out of adjustments and such no guarentees the noise will be gone,BUT at least you know what's in there and it isn't going to fly apart.
