36/38 b magneto
J.BENNETT
02-13-2007 04:36:28
just acquired a 36 b and 38 long frame unstyled b and someone else beat me to the carbs and mags. i was just curious if there was a replacement model of mag instead of the drv2b ?
the carbs are the dltx10 and have seen plenty of them around.but i am worried(well its really my wife) that i will have to pay $400-$600 each for the original mags unless someone maufactures another option. i'm new to b's and haven't purchased my resource books yet so any input would be appreciated greatly. i could stand to go to a few shows and pick up some donor mags but i was just unsure what you could replace the original with. thanks
Glen in TX
02-13-2007 11:56:16
 Re: 36/38 b magneto in reply to J.BENNETT, 02-13-2007 04:36:28
Yeah kind of ridiculous what some want for a worn out FM-RV mag that you might pay that for and it still may not be in top notch running shape and take another $100-300 to fix it right. You can buy a far superior Wico XH new for about $300 or spend up to $200 or much less to rebuild a used one.
Duane Larson
02-13-2007 06:33:36
J. Bennett,
If you went to a Deere dealer for a replacement magneto you would have received either the Wico C477 (from 1938-1947) or a Wico XH477 (1947 on). They both have long-lug impulse drive cups (go to www.robertscarbrepair.com for a pix of the long lug and short lug drive cups). Since the drive cups are easily interchanged, you will often find a long lug drive cup on a C1042 or XH1042 also. If you do get a C477 or C1042, look carefully on the side of the metal flange for a number 3 cast in above the identification tag - that indicates a later magneto with an improved housing, and you do want that. If there is not a 3 there, go find another one.
Other replacement magnetos are also available, but less common, including a Fairbanks Morse FMJ2B6 and FMX2B6.
BMAN
02-13-2007 04:45:57
I use the Wico X
