4010 brake pads
Mark / Wi
02-12-2007 05:34:35
I have heard that trans-hydraulic oil type can be a factor with brake pad brake up on the 4010D. How many of you have experienced this problem and what kind of trans-hydraulic oil were you using? We have always used after market brands that state they meet or exceed the JD standards. So far we have not had any problems. I thought moisture was the biggest problem for brake pads. Thanks in advance for your comments.
Glen in TX
02-12-2007 09:57:10
 Re: 4010 brake pads in reply to Mark / Wi, 02-12-2007 05:34:35
Some have had problems with some of the cheapest aftermarket oils not being compatible with the wet clutch or brake materials and those will cause the pads to come off when used later and you'll find the brake material all gunked around the sump pump screen in bottom of trans along with primer paint if it has such in trans case. Best thing to do is just stay away from the cheapest hydraulic oils and only use JD or popular trade name oils. The brakes will be noisy and tell you if you aren't using a quality oil. We used aftermarket oils for years also in new generation tractors with no ill effects other than extra brake noise. When local JD dealers started having oil booking sales so you could buy it in bulk ahead of time and save on price it was really hard for any other local oil dealer to beat the JD oil price. If you just walk in to buy a 5 gal. bucket or less yes it can get pricy there. Ask your dealer if they can also fill your cans from a bulk barrel and that might save you more also. We also seemed to have more load control shaft seal failures using aftermarket brand oils also that didn't seem compatible with seals.
