From the John Deere Model "H" Restoration Guide, we have - - - 7. What is distillate, and what combination of current fuel types will "equal" distillate? What mix (if any) will make this little tractor sound, smell and perform as it did when burning distillate? Distillate was a by-product of an oil refining process now forever changed -- the change driven by increased demand for specific fuels to support the World War II effort. The need was for gasoline and lots of it! Distillate was a left-over from crude once the popular fuel forms distilled out, these coming out of the mix in order of volatility e.g., methane, butane, propane, and so on. The crude is a mix of liquid hydrocarbon chains, and when heated, the liquids convert into gases, the lighter ones boiling off first, and heavier ones thereafter such as gasoline and kerosene. At some point down in the process, a mix of heavy hydrocarbons remained -- this mix was referred to as distillate. With demand for specific fuels for WW2, the distillation process was abandoned (no more distillate), and in its place the "cracking" process wherein all of the hydrocarbon chains in the crude are split out and then recombined into the hydrocarbon chains needed to produce specific fuels such as gasoline, kerosene and diesel. As for what mix of today's fuels will replicate performance and smell of those old days, there seems to be wide variation by folks who have both knowledge and experience. A summary follows. Letting G = Gasoline, K = Kerosene, D = Diesel, and FO = Fuel Oil, and with numbers for percentages, here are some combinations that do work: (50G + 40K + 10D), (25G + 75D), (33G + 67D), (50G + 50D), and finally we have (60G + 40FO). The last combination was called "power fuel". Remember, engine temperature must remain above 180 degrees to burn these fuel combinations. If not, low power and plug fouling result." Early literature actually calls out 190�F as the low end of opeating range for distillate.
