7000 planter vs. 7000 max-emerge?
MichaelNEIowa
02-11-2007 17:24:09
I'm in the market for a no-till corn planter to pull behind my IH 806 diesel (90hp) tractor. The 7000 series seem like nice machines for the money. I only have 140 acres to plant and the land on my farm is rolling. I have a few questions:
1. Are all 7000 plateless?
2. How many rows can/should I pull with a 90hp tractor? 4, 6, 8?
3. Are there certain years of planter I should look for?
4. How do you tell if it is a max-emerge planter?
5. Which is better: liquid or dry fert?
6. I see some 7000's that are cheap and some that are expensive. Why?
7. I see some that are 38" rows and some that are 30". Is it easy to change the row width on these planters or are they fixed at one width only? I've heard the 4 rows aren't changeable due to the transport wheel location.
8. Are parts easy to come by and are they relatively inexpensive?
9. What should I expect to reasonably pay for a planter like this?
Any other advice?
MichaelNEIowa
02-13-2007 18:16:31
 Re: 7000 planter vs. 7000 max-emerge? in reply to MichaelNEIowa, 02-11-2007 17:24:09
Thanks for the info! Now I can shop smarter.
andy r
02-12-2007 19:44:53
Some 4 row 7000 John Deeres had fully adjusted transport wheels. I have a JD 7000 and moved it in to plant 30 inch corn. It is the Conservation Tillage model. I believe they (conservation models) all had the moveable lift wheels with individual cylinders. It also has a bigger main frame which I believe is 5" by 7". Works well for me with an 80 acre farm. But at 10' a pass it takes too long and I even want to go to a 6 or 8 row. Some of the rigid lift tube models were actually made in 30 inch models. The 7000 is an excellent planter. I consider it to be less technical and more maintenance free than newer models. I personally like the dry fertilizer. It is cheaper than liquid. I put down about 75 lbs of Phosphorus and 75 lbs of potassium. There is a little nitrogen in my mix also. That is the only P and K I apply and according to soil tests I am maintaining my fertility levels. I installed Yetter openers for a little deeper application. If the no-till coulters are on the planting unit I would recommend the heavy down pressure springs as the weight of the unit isn't enough when the boxes are not full. The 7000 planters with the no-till coulters on the main frame work excellent and at times they sell cheap at auctions. People think the unit coulters are better but that is not the case. The frame attached coulter WILL GO IN if the springs on the rods have pressure. The frame of the planter and fertilizer hoppers provide the weight.
DSK
02-11-2007 19:30:14
On the 8&12 row planters, make sure to check the wheel frame pivot bushings. Also try to find one with the later style moniter.Model 100,200 or 250. The moniter could be a factor in the price of the planter also.
Mike Aylward
02-11-2007 17:45:10
Michael, you have asked a lot of good questions and I will try to answer a few of them. First, all 7000 planters are "MaxEmerge" planters. Most of them were plateless but not all. For the first year or two the plate option was ordered by some folks but after that were not as common, although it was available clear until the end of production. You should have no problem pulling any of the planters you listed. If you will have someone else do your harvesting for you then you need to ask around in your immediate area and see what row configuration is most commonly used so your rows will match the equipment available. The 30" rows will likely be more common anymore but in few localities they still use 38" rows. Also, most chemical dealers will be spaced for 30" rows as well so this will make it easier for you to get your spraying done in a timely manner. Practically any John Deere dealer will have parts for these planters and there is a sizeable aftermarket supply of the common parts as well. Also, many of the parts will interchange with Kinze so if you have a dealer close by they will often work as well. Most of these planters are inexpensive as the newest one is over 20 years old by now while the oldest is 33 (1974). In the sizes you are looking at there are not a lot of drastic differences from first to last and any will do a good job for you if it is in good shape. If you are planning on no-tilling be sure that your planter has the coulters up front on the unit or at least has the mounting bolt holes for them as the very earliest planters were not drilled for them. You will see a flat plate in the front of the opener and if there are four holes in this plate you are ok. If not, you will have to get a template and drill these, which is not hard but is not fun, either. Liquid fertilizer is easier to use than dry but either fertilizer will work fine. You can get more of a custom analysis with dry fertilizer but you have to be set up to handle it. Liquid fertilizer can simply be pumped from tank to tank, but you are somewhat limited in the analysis you can use because if you put in too much of certain kinds of fertilizer your mix gets too thick and will not pump. Your local fertilizer dealers can tell you what works the best in a planter system. I have used a 7000 planter for many years and it still does a very good job of planting. They respond well to favorable treatment so don't be afraid to spend a little money on it each year to keep it in good shape. When you order seed, while the planter will plant about anything you put in it (plateless style) they seem to like large seed better and will do a better job. I like to ask my seed suppliers for the largest round kernels I can get with large flats or medium rounds being my next choices. When you get a planter be sure and get an Operator's Manual, and be sure you get it for the right serial number because in the sizes you list there are at least three different versions. Hopefully this will be enough to get you started. If you have any other questions feel free to ask. Mike
