50 G axel hub
Gary Childs
02-11-2007 13:50:29
I have been trying to move the rear wheel hub with no luck. I have a ten ton puller and used all types of penatrating oils and heat. What next? I don't want to cut it off but that might be my next venture. Any other ideas? thanks Gary
jd4010d
02-12-2007 10:37:14
 Re: 50 G axel hub in reply to Gary Childs, 02-11-2007 13:50:29
A few yrs ago, I worked part time in a local machine shop. A customer brought in a pair of "G" axles from a "puller" he was building. He had tried, without success to get the hubs off. We ended up placing them in a 50 ton press--One moved at about 40tons or so, but the other wouldn't move with the full 50 tons pressure, so we started heating--eventually it let go with a sound like a rifle shot! Moved only about 1/8" that first time, but the rest was easy. The owner of the shop had just purchased a new CNC mill,& wrote a program to make a set of adapters, so the customer could use 9 bolt pressed steel wheels. I also made a "flatback" for that tractor to replace the "power-trol". He said the power-trol weighed something like 300 lbs.--The flatback I made of strap iron & some 12ga sheet metal, weighed 12lbs.!
brian0
02-11-2007 17:51:34
To move the number series hub make a large broad punch to drive only one wedge back at a time. the flanges are not tough enough todo this.I used a truck axle 2 feet long with a 4 inch spade welded on. hit this very hard on the small end like you don't know better so as to not mushroom the wedge
DSK
02-11-2007 17:13:27
If you have the time and patience, leave the puller in place and soak and pound the hub every day, then tighten up the puller to max pressure.You might have to repeat this process for a week or more, but eventually it will go. Liquid Wrench has been around for a long time, and I haven't found a penetrant that works better. I know of several cases where the axles were removed from the tractor and the hubs needed to be pressed off the axles.
Pappy
02-11-2007 16:42:25
I had one stuck on an "A". After soaking for a long time, I loosened the hub clamp, left the bolts in place (loose) and drove the tractor around the pasture for an hour. (slowly with no hard turns) When I got back, the hub had moved on the axle about 1/8 inch. From there on, it was not hard to pull the hub.
