JD A 1936 Rear Axle Housing
Gino
12-31-1999 16:33:09
I have a nice 1936 Model A Open Fan shaft tractor with a cracked Rear Axle housing. I have tried welding, and JB weld, with no success. Iam now trying to locate a replacement housing. Has anyone replaced a rear axle housing? Are the axles and seals hard to properly replace? Thank you.
Jarrod
01-02-2000 19:18:10
 Re: JD A 1936 Rear Axle Housing in reply to Gino, 12-31-1999 16:33:09
I've probably got one too. sell you what's left of the tractor cheap.
STMTS
01-01-2000 11:29:31
We have a housing for sale.Casting # A828R
zane
12-31-1999 20:00:41
No trick at all to replace parts, including seals and bearings. If you don't get an exact (same casting number) replacement, make sure everything will fit. Otherwise the axles may not be the right length.
