1940B fuel line filter
Phil Ralston
02-10-2007 16:21:10
I had the carberator rebuilt by Roberts. They recomend cleaning the fuel lines. How do you clean a steel line? Can a filter be installed in line and if so what size? Rebuild is a investment.
Thank You for your help.
Pappy
02-10-2007 22:37:12
 Re: 1940B fuel line filter in reply to Phil Ralston, 02-10-2007 16:21:10
Click on "Parts and Pieces" on the left menu. Go to about page 4 and see item #52. It is my idea of a proper fuel filter for the old tractors.
It has solved all my problems with scale-rust and sand in old fuel tanks.
F-I-T
02-10-2007 20:09:10
Put a small cork in one end and fill them with Methyl Ethyl Ketone, available at any Home Depot paint department. That will remove any organic residue in the pipe. Treat them with Phosphoric Acid if rust is a concern.
If you want to go cheap, fill with hot lye water, soak for a day, then rinse out with hot water. Then pull a large string through. Tie one end to the work bench and then slide the tube up and down the string, rolling it as you do. It'll be scrubbed completely clean.
johns48jdb
02-10-2007 19:03:03
after you clean it good you might want to try this trick. i have had several tractors over the years that kept getting trash down in the sediment bowl or stopping the outlet end up coming out of the tank. so i found some stainlees steel mesh wire that was real, real fine and cut off a piece about an inch and a half wide. i roll it up real tight and force it into the opening in the sediment bowl that screws up into the tank. even if there is some sedient in the tank it would have to get an inch deep before it will stop up this screen. wal mart sells a product called super clean by castrol in a purple jug. only use this product with lots on ventilation or outside. it will cut the paint off of anything in about five minutes so don"t get it on painted surfaces, but its a real good cleaner.
Mike M
02-10-2007 17:56:14
Take them off and blow a sandblaster through them. Then blow out real good with air. Unless they are varnished them soak them in carb. dip bucket and wash them first.
jdfanatic
02-10-2007 16:34:37
I would soak them in somme mineral spirits and then run a wire through them
