I guess I don't see that there really are any "interesting issues for your heirs will deal with such assets once you pass on leaving behind fully depreciated assets".... I mean, if you have a $100 asset that you depreciate down to 0, deducting it in portions to counteract income, that's one thing. That's a deduction against your income because the IRS says the item you used to help generate that income is wearing out and will someday need to be replaced when it is unusable and worthless, like a shovel or a chainsaw. That's the income tax portion of the tax code. Once you die, your heir(s) get the asset, and say it is now worth $200. They pay an inheritance tax fee on the appraised value of the asset they received (whether they choose to re-sell it or not), whether you have depreciated it fully, partially, or never at all. Your personal auto is good example, an item which typically is not depreciated. Your heirs gain it from your estate, and it is valued at the current appraisal LESS ANY MONEY OWED in case you still have a loan against it. That's the new basis for the transferred capital, Asset value less any liability, not the remaining balance of any depreciation or not. Depreciation has nothing to do with the value that the heir or estate pays inheritance taxes on. So if you left your newer John Deere tractor in the estate, fully owned with no encumbrance, and it was half depreciated, it would still be valued in the estate at its current appraised value, whether you had depreciated any of it during your use of it against your personal income taxes or not. If it's worth $50,000 in the market, that's the value that it will contribute to your estate's value. That's why it is called an inheritance tax and not an income tax. Two different codes, right? Your income stops when you die, and at that moment, so does the periodic deduction of depreciation against it. Now to the tractor buyer, what's best for you is hard to say based on the limited information, but one thing is for sure. You can depreciate something over time because it is expected that it will have been worn out to worthlessness over that time. That's what depreciation is. How you choose to calculate that deduction whether it is 10 years straight, or Section 179, or BR549, is up to you and how and if you qualify for depreciation under the tax code. Now, if it the asset happens to appreciate over in time instead of truly depreciating, you are going to have to pay for its true value either when you sell it, or when you die and your heirs sell it, though it will be a different time and at different tax rates. I think maybe the simplest way to visualize this is that you only get to depreciate the amount that you write the total check(s) for. So if you depreciate a new 4020 from $10,000 to nothing, then you trade in the 4020 on a new 4440 at $30,000, and they give you $8000 trade-in credit, then you only get new depreciation of $22,000 from the 4440, because that's what you wrote the check for, right? The 4020 really only cost $2000 out of pocket. Total outlay, $10,000 + $30,000 = $40,000, less return from resale, $8,000, for a total outlay of $32,000, which equals the total reported depreciation $22,000 + 10,000 = $32,000. When you eventually depreciate the 4440 to nothing, then anything you get for it by selling it will be taxable. I just don't see that the amount of depreciation, if any, will cause any interesting issues for your heirs.
