2130 oil leak
chris hanks
02-09-2007 10:33:09
Hey guys. I have a small oil leak underneath the oil filter attachment. It is not coming from the gasket where the filter attaches but behind the arm the filter sits on. It has been VERY cold here the last few weeks and I also had the boot around the shifter crack because it was so brittle. Is the oil leak a hard fix? I am still waiting on my manual. (will be 3-6 wks according to deere...) THANKS
cannonball
02-10-2007 04:19:19
 Re: 2130 oil leak in reply to chris hanks, 02-09-2007 10:33:09
you are talking about the engine cooler on the oil filter right.....shows a R53543 O-RING under the oil cooler...the hyd filter on the 2 2130's here are AR75603 but some use AL25554...hope this helps
MAY GOD BLESS THE USA
CANNONBALL
02-10-2007 04:28:40
 Re: 2130 oil leak in reply to cannonball, 02-10-2007 04:19:19
if it has hi-low then it will use the AL25554..
chris hanks
02-09-2007 10:50:33
 oil recommendations? in reply to chris hanks, 02-09-2007 10:33:09
I have also had a lot of trouble finding what type of hydraulic oil filter it needs. I looked on JD parts and was unsuccessful. Also, any recommendations of types of motor and hydraulic oil?
Tx Jim
02-10-2007 04:13:45
 Re: oil recommendations? in reply to chris hanks, 02-09-2007 10:50:33
Hyd oil filter part # AR 75603. Tx Jim
G/MAN
02-09-2007 13:33:47
Just about every "modern" JD tractor hydraulic system (post two-cylinder era) uses JD Hy-Gard transmission/hydraulic oil. The only exceptions might be the hydrostatic compact-utilities which may use Low-Viscosity Hy-Gard - I don't work on those enough to know right off the top of my head. I'd recommend Hy-Gard, but any QUALITY trans/hydraulic fluid meeting the same specs as Hy-Gard should work okay. I emphasized quality because there is a lot of cheap worthless oil for sale out there. As for engine oil - pretty much the same story. Deere Plus-50 15W-40 is as good as any heavy-duty engine oil out there, but any other high-quality diesel oil will work - Shell Rotella, Mobil Delvac, etc.
chris hanks
02-09-2007 13:36:27
 Re: oil recommendations? in reply to G/MAN, 02-09-2007 13:33:47
Thanks for the recommendation.
