1952 B with Frame Dammage
JD B man in WI
02-09-2007 08:43:48
The frame is cracked from a loader previously mounted to the frame. Welds have been made up by the flywheel and someone also tried to weld the steel frame to the front cast under the wheels. Has anyone had experience with restoring this type of dammage to pressed frames on B's? The tractor runs well and is still for sale asking price of $1800 which I think is high despite the frame dammage. Any help would be great!
Steve Crum
02-10-2007 06:30:06
 Re: 1952 B with Frame Damage in reply to JD B man in WI, 02-09-2007 08:43:48
As previously stated, I would be inclined to pass on this one. $1,800 is plenty for a solid B without obvious damage. There's still a lot of good ones out there.
You could be buying some big money problems.
JDBIA
02-09-2007 19:33:42
 Re: 1952 B with Frame Dammage in reply to JD B man in WI, 02-09-2007 08:43:48
I have a nice frame for $100 in Iowa
machinery-man
02-09-2007 10:15:13
With the damage my opinion would be to leave this unit alone and look at another one. While you can get one of the frames there may be other areas of heavy abuse..transmisson drive train ie....
otto stook
02-09-2007 09:01:45
if its been welded to the front bolster I bet the bolt holes are pooched,I get a good used frame and front bolster to take care of the problem,,or look for a different B,,,,otto
