12 Volt Generator for an older A
Loren in Iowa
02-09-2007 05:18:57
In changing a 1941 A over to 12 volts, will a generator from a later A fit the existing mounting bracket, for the 6 volt generator?
Jasper T
02-09-2007 14:13:44
 Re: 12 Volt Generator for an older A in reply to Loren in Iowa, 02-09-2007 05:18:57
I don't know first hand but I hear that you can put a 12V reg. on your old 6V gen. and it will work.
Myrlfrompa
02-10-2007 00:26:32
 Re: 12 Volt Generator for an older A in reply to Jasper T, 02-09-2007 14:13:44
Jasper I am running a B like that 12v reg on 6v gen and so far it is working fine. Pus to look at it it still looks like stock tractor till ya lift the seat.
Vermont John
02-10-2007 06:26:07
 Re: 12 Volt Generator for an older A in reply to Myrlfrompa, 02-10-2007 00:26:32
So, by changing the regulator on an A or B generator you make a 6 volt into a 12 volt? I assume you had to change the battery and bulbs. However, I hear that starter does not need to be changed. Will chaning the regulator to 12 v also work on an M?
Mike M
02-09-2007 05:54:53
I am pretty sure the mounting demensions are the same for the 6 and 12 V gen. so it should fit right in there.
