John Deere D fuel tank
bigtim72
02-08-2007 20:15:35
I have a 1934 John Deere D and the fuel tank was just sitting on tank brackets was there some kind of brackets to hold it in place? or did the hood just hold it in place? and I have no hood or hood brackets are they hard to find? or do they come with new hood? does anybody have a parts pitures? I have a parts book but it doesn't have any pitures. thanks for any help
bigtim72
02-09-2007 16:54:33
 Re: John Deere D fuel tank in reply to bigtim72, 02-08-2007 20:15:35
thanks for all the information Glen in TX and Mike M. Sounds like all I need is a new hood and i will be set
Glen in TX
02-08-2007 22:01:14
There were canvas webbing straps riveted to the tank saddle brackets for cushions and you can use webbing for some cushion between the tank and hood on top side also. In unstyled D part book PC658 on page 37 it shows the hood for your 34 D as Key 2A and depending on your serial number could have been hood AD744R or AD1014R. There were some small angle irons C1573R that were fastened to hood with 2 rivets and had a oval shaped hole for a bolt to go through angle iron clamping hood down over tank and bolts going through saddle brackets with nuts on bottom side to hold tank on. All of the unstyled JDs were this way with hood holding the tank on and only seperate bands were used on later styled tractors. Earlier Ds had holes in hood using some clamps. For a D hood I'm not sure who makes the best new right now but would try contacting Detwilers or K&K Tractor or other advertisers in the JD magazines or running ads for a used one.
Mike M
02-09-2007 06:07:55
 Re: John Deere D fuel tank in reply to Glen in TX, 02-08-2007 22:01:14
I wonder ? Will that hood fit on right with webbing on the top ? Is webbing still available from Deere ? I still have some left I bought from them years ago.
Glen in TX
02-09-2007 12:05:05
 Re: John Deere D fuel tank in reply to Mike M, 02-09-2007 06:07:55
Back then they may not have even painted under the hoods before putting them on and tanks were probably just galvanized and then all painted after putting together? I don't think they used webbing on top of tank between it and hood originally either. I usually liked to find some very thin canvas or nylon webbing and put just a small piece between hood and tank anyway and paint the tank and underside of hood also. You do need some web cushioning on tank bracket saddles though and can rivet as originally or just glue it on. Many military surplus stores will have the old styled cotton canvas webbing instead of the nylon stuff.
