No motion
KTown
02-08-2007 19:26:47
1965 400JD Still no forward or revers. Everything else works, bucket moves power steer etc. Replaced Trans, Hydro and suction filters followed with 10 gal new JD Hydro oil. Pressure tested the forward and revers circut at the reverse clutch control valve and it is zero so tested it at the presure side (of the reverse clutch control valve) and had 10 psi. Where do I go next ? I am think of removing the rockshaft cover (no three point hitch option) or the shifter levers cover. I think I will be able to see the trans oil pump and lines from there for crackes. Anything I should be careful of in removing one or both of these? Please help needed the tractor yesterday to feed cows. Thanks in advance
donmyeil
02-09-2007 08:16:23
 Re: No motion in reply to KTown, 02-08-2007 19:26:47
Sounds like you have a reverser clutch /trans.pump problem .The clutch shaft drives the trans. pump , so no clutch or bad splines results in no pressure to reverser. The trans. pump is in between the trans and clutch housing. You wont see much under the rockshaft or shifter hsng. Best get a 2020-2030 teck manual to diagnose this.
