1946 JD D steering
Tom/Idaho
02-08-2007 17:11:46
Steers like a really big truck with tons of weight on the front axle. It's a two man and a boy job to turn the wheel when moving. I took the steering box apart and cleaned it but it doesn't help. Greased every zerk, nothing.
If I jack up the front axle it turns fine, but the minute the tires touch the ground it gets really, really hard.
Mother Deere told me the kingpin bushings and thrust plates are still available, so I will order them tomorrow. Anyone have any ideas on anything else? I have been told that a D should steer fairly easy. My 1927 D was very easy to steer compared to the 1946.
Thanks for any ideas or suggestion, Tom/Idaho
Experienced Same Thing
02-08-2007 18:55:25
 Re: 1946 JD D steering in reply to Tom/Idaho, 02-08-2007 17:11:46
My 1940 "D" started getting harder and harder to steer also. We found a NOS steering box and shaft that goes through the transmission at a dealer in Colorado I believe. Paid $200 for the parts, but it was worth it because it steers very easily once again.
Glen in TX
02-09-2007 12:11:11
 Re: 1946 JD D steering in reply to Experienced Same Thing, 02-08-2007 18:55:25
Yeah that would be nice if everyone could find or afford NOS parts like that. Geeze we use to pay that much though for 2 complete Ds in 80s and 90s.
Glen in TX
02-08-2007 17:42:49
It's just worn out after 61 years you know. You could have made the king pins out of oil hardened machine shafting. You might need them oversize to help take up wear anyway or put bushings in the axle beam. See what the lower bushing for steering shaft on RH side of trans looks like and if it's worn bad like they usually are you'll need to replace it and may need to pull the gear box and build up and turn back down the lower shaft also. The lower arm and splines can get worn and loose also. The steering gear in box can can wear on lower side or the housing wear off under it also requiring shim washers under it to realign it with the worm gear. Early boxes had a thrust washer under the gear and sometimes the thrust washer is just worn and requires a new washer or another shim washer. The shaft may be worn and require building up and turning down and bushing the gear box on upper end also. The cone bearing may be gone or shot under the end of worm gear also. You should be able to get thick and thin gear box shim gaskets from JD yet for shimming the worm gear then also or if JD doesn't have them try Greg Stephens 303-663-5246 [email protected]
