2020 starts great, runs then slowly dies
George in Georg
02-08-2007 08:28:00
third party image
Just inherited a 1967 2020 diesel that has been neglected and sat out in a field for a few years.
Changed the oil, fuel, air and oil filters, added fresh kerosene to the existing diesel in the tank, purged the air, and she cranked right up.
Ran great for a 10 minutes drove it around the field, then she slowwwww wwly began to lose rpms, sputter for a long time, then died.
Wait a minute, crank and she'll crank right up real strong but lose power much sooner and die.
She'll crank every time, no problem.
This is the first tractor I've ever owned.
Any help will be appreciated.
The photo shows how she looked when I first saw her.
Here are other photos as well.
Thanks!
Link
Link
http://i61.photobucket.com/albums/h80/Accurizer/Stanadynepump.jpg
dds-inc
02-08-2007 21:04:19
 Re: 2020 starts great, runs then slowly dies in reply to George in Georgia, 02-08-2007 08:28:00
my 2155 did that too. Found out that there was a broken bleeder screw in the fuel filter. Getting air in the system seems to be the obvious cause. Check and make sure that your fuel filter isn't bubbling... if it is, it's getting an air leak somewhere in the system. check from the tank all the way to the filter. I'm pretty sure its gotta be an air leak, since my 2155 used to do the same thing before i replaced that broken filter bleed screw.
George in Georgia
02-08-2007 08:47:57
third party image
Bob,
That "fuel starvation" problem makes sense. I once owned a Mercedes 240D and when the fuel filter would get clogged, that engine would show the same symptoms. Lose power and rpms then slowly shudder to a halt.
Although not in front of me here at work, I do have the little JD 2020 shop manual reprint. It does NOT go into trouble-shooting, so if you could slightly walk me through what you're talking about.....?
Should I remove that Stanadyne pump to look for this crud?
Thanks!
Here's how she looks with the tires all pumped up and after running around for a few minutes.
Bob
02-08-2007 08:58:43
 Re: 2020 starts great, runs then slowly dies in reply to George in Georgia, 02-08-2007 08:47:57
If the filters, lines, etc, on the supply side are flowing adequate fuel to the pump, the problem could be, as I posted, a restriction on the RETURN side. The Stanadyne pumps will cut off injection of fuel if the return circuit gets clogged.
Start by removing the return line, from the pump's top cover, then remove the COMPLETE fitting/valve it was attached to. The black plastic crud, if present, will be jammed up into the valve from the bottom.
George in Georgia
02-08-2007 09:32:02
 Re: 2020 starts great, runs then slowly dies in reply to Bob, 02-08-2007 08:58:43
third party image
Here's a much enlarged photo showing the top cover and the injection pump in general. Now I can see the top line and fitting you talk about.
Will that crud be from a disintegrated O-ring or anything I can replace? Or does that mean the entire pump must be replaced. Online I've found a place in Oregon that wants $575 for a rebuilt one.
Thanks!
GG
Bob
02-08-2007 09:57:31
 Re: 2020 starts great, runs then slowly dies in reply to George in Georgia, 02-08-2007 09:32:02
The seal and parts kit is only about $30.00, and can be replaced by you, if you're careful, and keep things CLEAN, and have some basic tools, and perhaps one special tool, but there's a $$$ potential for damage, if you mess up.
NO critical calibrations or settings will be messed up, if you don't touch anything you don't need to.
There's a couple of other guys on here who will tell you to "go for it", and an bunch who will say "don't touch!".
Not knowing your mechanical aptitude, I won't comment, on way or the other.
You can still get a pump tech manual from Deere.
First off, though, get that fitting out of there, and see if it is REALLY clogged.
Otherwise, there could be problems in the fuel supply side of the system.
msb
02-08-2007 20:01:50
 Re: 2020 starts great, runs then slowly dies in reply to Bob, 02-08-2007 09:57:31
That tech manual sells for $115 .That will go a long way in paying a trained person to rebuild your pump and it will be done right.I am one of those who says have a professional do the work and it will be calibrated---something that can't be done without a test stand and proper training.Its not just about replacing parts.
George in Georgia
02-08-2007 12:37:43
Bob,
You made my day so far.
Thanks!
Bob
02-08-2007 08:37:09
Either fuel flow TO the injection pump is retricted, OR the fuel return TO the tank FROM the injection pump is restricted, most likely by a piece of the governor damper ring that has disintegrated into "coffee grounds", and plugged the housing pressure control valve/fitting that is screwed into the injection pump's cover.
You can remove the fitting, and clean out the crud (caution, there's a GLASS check ball in there), and it will run 'til it clogs again, if that's the problem.
CAUTION... continuing to run the tractor for many hours without having the IP repaired will make governor parts run "metal-to-metal", once the ring completely disintegrates, allowing the metal parts to rattle together, and put metal filings in the fuel system.
That little tractor is a KEEPER!
buckeye al
02-09-2007 15:35:58
 Re: 2020 starts great, runs then slowly dies in reply to Bob, 02-08-2007 08:37:09
Looks like a keeper to me.
I'll bet it's not long before they're shopping for some better seating arrangements though!
