60 with a whine
Kemper
02-08-2007 07:36:18
My 60 has a whine just when driving it, sounds like it is the first reduction gear,or close to it,could there be a bad bearing or just wore gears?
The Dukester
02-08-2007 08:56:03
 Re: 60 with a whine in reply to Kemper, 02-08-2007 07:36:18
I had a similar problem with my late styled A..found it was the outer first reduction shaft bearing in the cover...you can check it by pulling off the little 2 eared shaft end cover just behind the pulley...the bearing is loose in the housing in my tractor...not too bad, but loose enough to give the gears a little extra clearance and let them howl a little.
machinery-man
02-08-2007 07:47:09
wear and tear...put in about 3or4 cans of STP in the differental oil to quieten those gears....
Kent Petersen
02-08-2007 17:15:50
 Re: 60 with a whine in reply to machinery-man, 02-08-2007 07:47:09
you can by that brg for about the same money as four cans of stp. is stp new name for restoration take a little and fix it right Kent
dds-inc
02-08-2007 21:06:14
 Re: 60 with a whine in reply to Kent Petersen, 02-08-2007 17:15:50
well, a new bearing ain't going to take but maybe 50% of the noise out. The rest of it is the worn out gears. Trust me, bubba.
