Hi crop weights
collegeboy
12-30-1999 19:20:47
I just discovered one of the weights in my possession matches the part number for a hi crop 40. Is this worth anything, or doesn't it matter? I'm not sure how numbers matching people want these tractors these days.
collegeboy
collegeboy
01-01-2000 12:36:15
 Re: hi crop weights in reply to collegeboy, 12-30-1999 19:20:47
Thanks for the responses. Sorry for the lack of info, here's more. It is a rear wheel weight, and as far as my parts book shows, the part # only matches the hi crop. The other tractors have a different style of weight. The only other feature/number I can find is a round head-straight slot screw. What was this for? It is quite rusted.
So, do I advertise this for sale? I don't need it. The tractor it came off had cast iron/steel rims. If someone else wants it, mail me with some info.
Thanks
collegeboy
CLOONEY
12-30-1999 19:38:23
Collegeboy, what is the casting # on the weight? Also does the # ONLY FIT a highcrop or does it fit a reg. & a highcrop. If its a wheel weight it might be something special,if its a ft.weight I (think) its the same as a standard 40.
Nate
12-31-1999 11:50:13
 Re: Re: hi crop weights in reply to CLOONEY, 12-30-1999 19:38:23
If it is a front weight it fits highs, standards, utilties, two-row utlity and specials that casting number should be M2546T inner, M2547T outer, they weigh 145 lbs. each. They also fit 420-430 highs, standards, utilities, specials. They made a rear wheel weight for just the high crops.
