Do 420's whine in the Transmission?
Dan V
02-07-2007 17:15:52
Do 420"s have a common problem with a whine in the trans.Someone told me this a while ago and I was wondering if it is true????
buickanddeere
02-09-2007 18:01:13
 Re: Do 420's whine in the Transmission? in reply to Dan V, 02-07-2007 17:15:52
If the bearings are good and the clearances correct. You will have to learn to like the whine.
buckeye al
02-09-2007 16:00:55
Our 40 W has such a howl in 4th, you hate to throttle up! It cries pretty well in 3rd too and that's the gear used most! Have gone hunting for the cause more than once and never found a bad or loose bearing, shaft or bad thrust washer any place. Seems as though some howl, some don't.
I'm sure they didn't sound like this new! I've wondered if there was a treatment problem with some gears letting their faces wear prematurely making them whine. Other batches or other gears were maybe better hardened & better resisted wear so they didn't get noisy through the years? On ours, when the engine is holding it back (going down a hill) quiet as can be. Get to the bottom and start up the next hill & HELLO!
This 40 W has been howling about the same for the 20 years we've had it! Tough (but noisy) little tractor!
Agree that the heavy oil helps.
dds-inc
02-07-2007 18:52:51
I have a completely worn out 430. It's so wore out that the oil almost goes out of the tranny just as fast as you pour it in.
It DOESN'T WHINE. Not one bit.
Henry M
02-07-2007 17:36:26
Dan
I think that it is only if you have a "winer"
It seems like once a winer always a winer, not matter how many bearings and stuff gets swapped around.
mine has a high pitched wine in 2nd and a low pitch growl in 5th. It has been on the bench completely apart two times and it still basically sounds the same. The last time I even swapped out the drive and driven gear for 5th.
You got me!
Wayne in Tn.
02-08-2007 08:29:03
 Re: Do 420's whine in the Transmission? in reply to Henry M, 02-07-2007 17:36:26
Henry has sumed it up. If you have a Dubuque that don"t whine, growl, roar, you are lucky. I have chased that "growl" in a bunch of them, with no luck. Like Henry, I have just about changed everything in the transmission, except the case, and still have noises.
The good thing is: It don"t seem to hurt anything. I guess just 50 plus years of wear on everything. I think some of them started making noises shortly after bought new. I can remember as a kid, we always knew when our neilghbor was passing our house on his 40, by listening for the gear whine.
Now, I just fill them up with 140w gear oil and it helps on some of them. Those straight-cut gears may be some of the cause.
