Electrolysis FIT and others
WyoDave
02-07-2007 16:57:12
Quick electryolysis question for you all. First of all Frank I"ve got your site book marked and have read your explanation and procedure. Thanks a bundle. My question is, is there any size limit to the process. I"ve been given a plastic 250 gallon tank that measures about 4"x4"x3" and I was wondering can I set up an electrolysis tank big enough to do large parts? I couldn"t find where you addressed this anywhere. Thanks again.
David
F-I-T
02-08-2007 07:22:11
 Re: Electrolysis FIT and others in reply to WyoDave, 02-07-2007 16:57:12
Dave:
You could use a swimming pool if you like. There used to be 5 or 6 franchise places across the nation that would "dip" entire classic car bodies. They advertised in Hemming"s Motor news for years. I am presently building a new tank foom a 150 gal plastic oval stock tank. I also used a 55 gal plastic drum and cleaned one-half of a hood at a time that way.
The primary limiting factor is that you should always have more sacrifical electrode surface area than the part to be cleaned. Also, the closer the proximity of the electorde to the part will speed up the process. Electrolyte concentration can only be as much as the saturation point of lye or washing soda in water. I have never approached that, and I have a 400 amp, 5 volt power supply that works fine. I like the lower voltage because I can put my hands in the bath at any time and never exceed galvanic skin resistance, so my hide is plenty of insulation.
Frank
Scott Griffith
02-08-2007 03:45:31
You may have to increase the size of your electrode when going with a bigger tank. In doing so you will be pleased with the results. I have a plastic 55 gallon drum with the top cut out which has worked great, even for hoods.
Scott
msb
02-07-2007 20:59:59
I have an old Snyder (Sutan came in it) poly tank . 210 gallon capacity--works fine.Big enough that a tractor hood will fit in,one end at a time.
dds-inc
02-07-2007 18:56:43
well.... it can only be made so obvious that you can only fit parts that will fit in the 250 gallon tank!!!!
