Hey Gman
DP
02-07-2007 14:23:47
Just catching up on back posts, and caught your post back on page 6. Time sure flies when your having fun! Been busy here too. Allen stopped in this morning for a little bit. As cold as its been, people are finding things to do out of the weather. Thinking about reringing my 730D. Its sit for years, and I think the rings are stuck. I've overhauled lots of tractors, but have never been to one of them.
G/MAN
02-07-2007 15:39:13
 Re: Hey Gman in reply to DP, 02-07-2007 14:23:47
I've never been into a two-cylinder diesel at all besides a little bit of service work changing oil, etc. I would like to have one, though - anything from an "R" through an 830 would work fine - I like the standard-tread diesels more than the row-crops. If you decide to do yours, you need to talk Allen into getting his 730D whipped into shape also. Do you have a plow to go with that 730?
DP
02-07-2007 19:25:26
 Re: Hey Gman in reply to G/MAN, 02-07-2007 15:39:13
Bought one in hopes of getting a 730 or similar several years ago. Bought a John Deere 825 3X16 roll-over, but it like the 730 isn't quite whipped into shape yet. Do have a 3X16 that I took to local plow day here this fall with the 630, and also a 3X16 pull type that also went to the plow day with the 70 gas.That was some tough going! Could have used the 730 that day. I think as soon as I get this guys 50 up and running for him, I'll tear into the 730. Guess I'll never learn any younger.
Matt_In
02-07-2007 20:41:49
 Re: Hey Gman in reply to DP, 02-07-2007 19:25:26
When you get yours done and you have learned everything, I will then send you my 720 and 730.
DP
02-07-2007 20:57:57
 Re: Hey Gman in reply to Matt_In, 02-07-2007 20:41:49
Oh I don't intend to learn everything! Just figure to learn enough to go have a little fun with a tractor running like its supposed to. I won't turn any tractors down though if you want to send them! I'm sure I can make room for several if the need arrises! You get your G all fixed up yet?
Matt_In
02-08-2007 07:10:25
 Re: Hey Gman in reply to DP, 02-07-2007 20:57:57
I have all the parts there to put it back together. Just when the shop is 0 its hard to pick up a wrench. Just doing some little things like cleaning the gas tank, new plug wires, new temp gauge. Just getting running so I can disk with it come spring.
